Results 1 to 22 of 22
  1. Anonymous
    Guest
    I know about video codecs and audio codecs and also containers
    But I don't know anything about subtitles
    How many types of subtitles and which one gives best compression
    I have seen .srt and .ass subtitles
  2. Anonymous
    Guest
    Basically there are text based subtitles like srt and image based subtitles like sup used on dvd or blu-ray
    srt is the easiest to work with
  3. Anonymous
    Guest
    .srt or .ass which gives low file size?
    Or both gives same file size?
  4. Anonymous
    Guest
    I don't think there is much difference in file size, both are text based.
  5. Anonymous
    Guest
    So .srt is easiest?
  6. Anonymous
    Guest
    In my opinion yes
  7. Anonymous
    Guest
  8. Anonymous
    Guest
    .srt or .sup which gives low file size? @jan5678
  9. Anonymous
    Guest
    sup are image based subtitles, so srt is the lowest file size.
    And you can't easily edit sup, so if you want the easy way go with srt
  10. Anonymous
    Guest
    Thanks✨
  11. On the other hand, SRT is the least flexible, capable, and consistent. The base spec doesn't include formatting options. Though some players accept some HTML tags for things like color, position, size, font, etc. So how they look depends on the player.
  12. Anonymous
    Guest
    So different types of subtitles has its own advantages??
    But I want the easiest subtitles format so which will be good?
  13. Anonymous
    Guest
    @jagabo
    Absolutely true, srt is simply flat text. If there is need for more functions there may be other formats but for the sake of simplicity srt is the easiest to work with
  14. Originally Posted by kirito View Post
    Just like everything else in the world.
    It depends on what you want from your subtitles, where they come from, what players you use, etc.
  15. Anonymous
    Guest
    Uhmm I am just a beginner in video encoding which subtitle format will be good for simplicity?
  16. The question has already been answered.
  17. Anonymous
    Guest
    Give me final answer
  18. You were already given the answer.
  19. Anonymous
    Guest
    Nope, you are confusing me��
  20. What's best for you depends on your needs. Nobody here knows your needs.
  21. Anonymous
    Guest
    Please read back this post, i already gave you a answer
  22. Anonymous
    Guest
    Okey ,
