hi, I've made a bdrip, basically I did a conversion from 23.976 to 25p, then I did a 313 frames cut at the beginning plus another 7 frames cut in the middle and then I've added the chapters.
when I play it on MPCHC, when skipping on some chapters, the video and sometime the audio too, they stutter.
the timing goes normally but the video hangs for a second and then accelerates in order to match the correct time.
I've already tried another XML chapter file, with the same issue, even worst.
I've tried to add the end-timings to the xml, no way, same issue.
I've also tried to manually correct the chapters timing rounding them to the 3rd number after the comma: same problem.
I can't figure out what is causing the problem. I need some help. please.
edit: I tried to play the same file with MPCHC-BE x64 portable and the problem has practically disappeared.
there is only a very perceptible lag on a single chapter, the one on which mpchc struggles the most, that is, it has the most lag.
while the skip on the other chapters are fluid where stuttering used to be.
I also tried to reencode the file at a lower resolution and it doesn't present any problem even on mpchc.
Results 1 to 1 of 1
Stuttering video
By masster in forum RestorationReplies: 3Last Post: 21st Aug 2021, 23:28 -
interlaced conversion stuttering
By fullhdfan in forum Video ConversionReplies: 3Last Post: 23rd Mar 2020, 13:58 -
playback stuttering in vdub
By Ryan88 in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2019, 11:28 -
Stuttering Footage - How to solve?
By MelleBax in forum Newbie / General discussionsReplies: 19Last Post: 31st Jan 2019, 05:22 -
Stuttering playback within editor
By Wayfarer in forum Newbie / General discussionsReplies: 2Last Post: 16th Jan 2019, 13:09
