[Attachment 62395 - Click to enlarge]
What is Encoding SW Lavf58.29.100?
Results 1 to 17 of 17
AnonymousGuest
Got it ,one more question can we change
Name of lavf58.29.100 to anything?
By editing metadata of video? -
mkvtoolnix header editor might be able to overwrite the field, but not totally sure. (never tried it, my guess is that the field is the 'writing application' field which should be editable)
If you use another container another tool will be needed.users currently on my ignore list: deadrats, Stears555, marcorocchini -
You can change it with a hex editor.
But you're limited to the same number of characters when using a hex editor.Code:General Complete name : C:\Purple Pigs\00001 - Copy (2).mp4.avs.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/avc1/mp41) File size : 49.2 MiB Duration : 32 s 334 ms Overall bit rate : 12.8 Mb/s Writing application : I changed it!
AnonymousGuest
I have to open video in hex editor then search for Lavf58.29.100, Then replace it to custom name right?
AnonymousGuest
Btw if we add so much meta data like
artist name
Movie name
Movie year
Actress name
Song lyrics etc then will it increases file size? -
yes, marginally - such data are optional and from decoder perspective not required to decode content.
That type of metadata is plain text. It's very small compared to the audio and video streams in an A/V file. It may account for few hundred bytes in a GB byte A/V file or a MB mp3 file. It's not worth worrying about. Some other types of metadata, like thumbnails and poster art (images), are bigger but also usually not worth worrying about.
By Anonymous543 in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2021, 10:40 -
.mp4 demux / Lavf58.76.100 error ?
By kalemvar1 in forum Video ConversionReplies: 3Last Post: 9th Aug 2021, 02:35 -
100% free software
By latecurtis in forum EditingReplies: 9Last Post: 21st Apr 2020, 11:29 -
Hardware encoding vs. software encoding
By Christopher2222 in forum Capturing and VCRReplies: 3Last Post: 29th Jan 2018, 11:35 -
Encoding problems - trying to replicate ZeeVee encoding.
By 1branchonthevine in forum Video ConversionReplies: 7Last Post: 10th Apr 2017, 18:03
