Hi, I'm trying to use "MPV-EASY Player" precisely because unlike the normal MPV it has a settings panel.. Despite of this I can't find a way to enable color management.
MPV claims to have color management but as far as I can see it doesn't seem to be active. The same video file looks perfectly color managed on MPC-HC and Premiere Pro. Does anyone have any idea how to tell MPV to consider the icc profile of my calibrated monitor? Thanks
If you can figure out how to use this: https://glowmpv.github.io/
Or try your luck here: https://forum.doom9.org/showthread.php?t=174841 -
Thank you very much!!! "Glow" was the perfect solution for me. I'm the kind of person who doesn't accept having to become a programmer to use a video player...
Thanks again
mpv.net media player
By stax76 in forum Software PlayingReplies: 91Last Post: 2nd Jan 2024, 05:03 -
Customize progress bar for mpv player
By speedlover in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2021, 15:06 -
Software or method to enable [easy] chapter editing by keyframes
By hayeled in forum Newbie / General discussionsReplies: 4Last Post: 13th Jun 2020, 14:50 -
strange behavior of mpv player
By osmium in forum Newbie / General discussionsReplies: 0Last Post: 25th Feb 2020, 12:39 -
ffmpeg, how to --enable-network --enable-protocol=tcp
By ramsh in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jul 2017, 07:06
