Results 1 to 15 of 15
    Dec 2008
    Spain
    I would like to make a video to show a counter like this:
    2010 - 60
    2011 - 69
    2012 - 84
    2013 - 92
    2014 - 97
    Each line should be shown alone on full screen and it should be shown for some 10 frames. Is there any program that can help with doing that? Maybe Avisynth?
  2. AviSynth can do that. Is there some algorithm for the count on the right? Or is it just a fixed list of numbers? How many number do you have? For a fixed list:
    BlankClip(width=640, height=360, length=10, fps=10)
    Subtitle("2010 - 60", size=150, x=30, y=100) \
    ++ Subtitle("2011 - 69", size=150, x=30, y=100) \
    ++ Subtitle("2012 - 84", size=150, x=30, y=100) \
    ++ Subtitle("2013 - 92", size=150, x=30, y=100) \
    ++ Subtitle("2014 - 97", size=150, x=30, y=100)
    Dec 2008
    Spain
    Thanks a lot, it works very nice in Avisynth3+ !
    It's just a fixed list of numbers. But if the numbers would be 1,2,4,8,16 etc (powers of two), can it be scripted?
    I still have a few questions please:
    - How can I change the background color from black to white?
    - How can I put two lines instead of a single line? (tried "\n" and it doesn't work)
    - And how can I write a title on the top for the entire duration of the video?
  4. If you can generate your numbers algorithmically you can use ScriptClip():
    BlankClip(width=640, height=360, length=100, fps=1)
    ScriptClip("""Subtitle(String(current_frame+2011) + " - " + String(current_frame*5+69), size=150, x=0, y=100)""")
    ChangeFPS(10)
    The left values starts at 2011 and increments by 1 every 10 frames. The right value starts at 69 and increases by 5 every 10 frames.
    Dec 2008
    Spain
    Very nice, thanks!
    How about the other questions? Background color and two lines of text
  6. You can specify color for the BlankClip using color= . In hex it would be $FFFFFF
    eg
    BlankClip(color=$FFFFFF)
    For two lines of text you can add other subtitle lines , and positioning with x,y or align
    http://avisynth.nl/index.php/Subtitle
    Dec 2008
    Spain
    Thanks!
    I see you do not define the duration for each text, the Subtitles have a duration of one second by default? What if you want the second text (2011 - 69) to last for 20 frames instead of 10 frames like other lines?
  8. I made my last post before seeing your post before it.
    BlankClip(width=640, height=360, color=color_white, length=20, fps=1)
    ScriptClip("""Subtitle(String(current_frame+2011),         size=100, x=320, y=250, align=2, text_color=color_cyan, halo_color=color_black)""")
    ScriptClip("""Subtitle(String(int(pow(2, current_frame))), size=100, x=320, y=350, align=2, text_color=color_lightgreen, halo_color=color_black)""")
    ChangeFPS(10)
    Subtitle("Big Title", text_color=color_black, halo_color=color_gray, size= 150, x=320, align=8)
    See docs:
    http://avisynth.nl/index.php/ConditionalFilter#ScriptClip
    Dec 2008
    Spain
    So you need ScriptClip only because you want to use current_frame variable, right?
    Dec 2008
    Spain
    If I may ask, how do you make mkv videos from Avisynth? I am using Virtualdub and it can't save MKV files
  11. Originally Posted by ziptip View Post
    vdub2 has mkv export support
    Dec 2008
    Spain
    Thanks!
  13. Originally Posted by ziptip View Post
    Yes. The runtime filters are the only way to get frame numbers.
    I used the x264 command line encoder. But yes, VirtualDub2 has built-in mkv export support. There's not much reason to use the older VirtualDub anymore.
  14. Here's a script using a single Subtitle line to output 2 lines of text:
    ScriptClip("""Subtitle(String(current_frame+2011) + "\n" + String(int(pow(2, current_frame))), size=100, x=320, y=260, lsp=-100, align=2, text_color=color_cyan, halo_color=color_blue)""")
    ChangeFPS(10)
    [Attachment 62388 - Click to enlarge]
    Dec 2008
    Spain
    Thanks a lot, really great scripts!
    I have another question but I will create a new thread for it. It's probably more useful for other people having the same question.
