Background :
Win XP (fresh install), Intel 1.6, ATI AIW, VirtualDub 1.4.8, 512 MB RAM, 40GB HDD, NTSC source, Panasonic 2.51 (standalone).
I've captured the video from my Hi8 Sony using VirtualDub in AVI file (~29GB size). There were no filters/compression. I just had 2 frames dropped for the entire clip. Then I start encoding the AVI using Panasonice MPEG Encoder 2.51 to MPEG-1 (1500Kbps). The total file has 89,924 franes. The encoder would do till the frame 12796 frames and then aborts with the message "Cannot get a frame data from the material file. Encoding aborted". I've even tried to encode from 12,900 to 89,923 frames. I still keep getting the same message and I was not able to encode the AVI that I've captured.
What should I do in such a situation ? The reason why I got this software is : the encoded quality is excellent. I could see better results than anyother encoder.
Any help is greatly appreciated.
PS : The captured AVI is 352x480, 29.97 fps. Even frameserving from VirtualDub also did not work !
Results 1 to 1 of 1
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Hank's Mpeg-2 Encoder
By unclescoob in forum Video ConversionReplies: 80Last Post: 8th Dec 2011, 12:16 -
What is the BEST Mpeg 2 Encoder Today?
By jrodefeld in forum Video ConversionReplies: 43Last Post: 2nd Jul 2011, 15:28 -
which mpeg-2 encoder would you choose...
By deadrats in forum Video ConversionReplies: 28Last Post: 12th Nov 2009, 22:11 -
Need Help Panasonic HDC-HS250P (AVCHD), USB to Windows Media Encoder
By planet_bill in forum Video Streaming DownloadingReplies: 1Last Post: 13th Aug 2009, 14:40
