Closed Thread
Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 84
    Jan 2022
    Italy
    Originally Posted by notaghost View Post
    Soon I am updating things please be patient
    Thank you! You are the best!
    Jan 2022
    Indonesia
    Hi is your website based on python?
    FYI i still wait
  3. Member notaghost's Avatar
    Sep 2020
    Pakistan
    discord=notaghost#9997
    Jan 2022
    sweden
    Great Job , we are looking forward , Thank you man !
  5. Member k2000's Avatar
    Jan 2022
    Canada
    Thanks notaghost for this site the return for soon?.
    Jan 2022
    Indonesia
    it still testing, and i'm waiting too
  7. I got
    Error 404:<br>0003|no assertion in payload.
    but last time before the site update (2 days ago) it works perfectly...
  8. Member k2000's Avatar
    Jan 2022
    Canada
    what is the use of option BUILDINFO: and JS FETCH REQUEST.
    Can you decrypt the json with the new notaghost version?.
    A big thank-you notaghost
  9. Member k2000's Avatar
    Jan 2022
    Canada
    what is the new trick to get the keys with the notaghost site ?.
    I do exactly the same thing before this update and error 403 or bad license.
    Jan 2022
    Indonesia
    yeah i got this error, but 2 days ago it's works
    Error 404:<br>{"error":{"code":-7008,"message":"[-7008] Failed to generate Widevine license"}}
  11. Member k2000's Avatar
    Jan 2022
    Canada
    ok
    Is this me making a mistake or having bugs to fix?.
  12. Originally Posted by beny94 View Post
    i believe it is because now you must upload your own cdm keys in order to use the tool
    That or use the cURL api
    Jan 2022
    Indonesia
    Where put the curl api??
  14. Originally Posted by beny94 View Post
    in your command prompt
    Fill in your data here and run it (this is from ghosts site)
    curl http://getwvkeys.herokuapp.com/api -d "{\"license\": \"https://widevine-proxy.appspot.com/proxy\",\"pssh\":\"AAAAW3Bzc2gAAAAA7e+LqXnWSs6jyCf c1R0h7QAAADsIARIQ62dqu8s0Xpa7z2FmMPGj2hoNd2lkZXZpb mVfdGVzdCIQZmtqM2xqYVNkZmFsa3IzaioCSEQyAA==\"}" -H 'Referer:http://getwvkeys.herokuapp.com'
    Jan 2022
    Italy
    With VDOCIPHER still not working, I get "WRONG SENDING LICENSE REQUEST"
    Still needs to be implemented or am I doing something wrong?
  16. Member notaghost's Avatar
    Sep 2020
    Pakistan
    Buildinfo is if you want to change the CDM (optional)
    For vdocipher go to scripts and download vdocipher.py file and run it with python . If you do not have python install it for free or tell me if you need .exe file?
    Js fetch request is optional too (using JavaScript) use lagacy python request (using python but server sided request)
  17. Originally Posted by notaghost View Post
    thank you for the updates
    does it work on channel4?
  18. Member
    Jan 2022
    Italy
    For vdocipher go to scripts and download vdocipher.py file and run it with python.
    Ok it works fine with python 3! Thanks!!!
    The only thing I have encountered is that it often gives me this error:
    File "vdocipher.py", line 83, in <module>
    start.main ()
    File "vdocipher.py", line 77, in main
    print ("\ n" + self.decrypter (license_request, license_response) .replace ("<br>", "\ n"))
    File "vdocipher.py", line 71, in decrypter
    raise Exception ('API ERROR')
    Exception: API ERROR
    Is it normal? What can it depend on?
  19. Hi,
    I tried using the cURL api method,
    curl http://getwvkeys.herokuapp.com/api -d "{\"license\": \"https://video.dmkt-sp.jp/license/widevine-challenge\",\"pssh\":\"AAAANHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABQIARIQ2JKmTSMoQ7Kr0t+E07qa1g==\"}" -H 'Referer:https://video.dmkt-sp.jp/play/?episodeId=10306233'
    but I've keep getting the following error...
    {"Error": "Error 404:<br>{\"errorCode\":\"EWL002\",\"errorMessage\":\"リクエストが不正です。[LS101]\"}"}
    May I know what I am doing wrong?
    Thanks very much in advance!
  20. Since Ghostīs site been updated no headers working for me. Everytime it says "WRONG HEADER" or some type of "ERROR".
    Often itīs always was like this before the update;
    User-Agent: xxxxxxxxxxxxxxxxx
    Accept-Language: xxxxxxxxxxxxxxx
    Accept-Encoding: xxxxxxxxxxxxxxxxxxx
    Authorization: Bearer xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    Content-Length: "xxxx"
    Origin: xxxxxxxxxxxxxxxxxx
    Anyone know what the problem is?
  21. psaframe
    Mar 2021
    Algeria
    start.main ()
    Make sure your PSSH is correct
  22. Member
    Jan 2022
    Indonesia
    i already try this but it same error {"Error": "Error 404:<br>{\"error\":{\"code\":-7008,\"message\":\"[-7008] Failed to generate Widevine license\"}}"}. I didn't have any CDM right now. But if cache is checked, i've got wrong key
  23. I can't get the PSSH.
    Any solution?
    [Attachment 63069 - Click to enlarge]
  24. To notaghost
    Thank for great site.
    I have some questions.
    Does your sever access license servers? Or our provider do by your script?
    No log, No cache? If not so, I think it is very danger.
  25. Originally Posted by VideoFenix View Post
    Any solution?
    You sure you installed Tamper monkey add-on with EME Logger script?
    [Attachment 63074 - Click to enlarge]
    I have never found a Widevine encrypted stream that EME logger didn't catch its PSSH.
  26. Member
    Jan 2022
    Italy
    start.main ()
    Yes, the PSSH is correct! it is the same PSSH that I copy and paste, it gives me the error, but after 2-3 times it works.
  27. Originally Posted by [ss]vegeta View Post
    Any solution?
    Thanks my friend.
    I have installed the extension and the script but got this error result.
    What is it, can you help me please?
    PSSH:
    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
    LICENSE:
    https://q321d2vicz2ra0.eu.api.amazonvideo.com/cdp/catalog/GetPlaybackResources?deviceID=cf443ec4-79ab-48df-af3e-f7b293594c68&deviceTypeID=AOAGZA014O5RE&gascEnabled=true&marketplaceID=A3K6Y4MI8GDYMT&uxLocale=es_ES&firmware=1&clientId=6163f72e-ebf6-45a9-81b3-cc155c38039c&deviceApplicationName=Chrome&playerType=xp&operatingSystemName=Windows&operatingSystemVersion=10.0&asin=com.amazon.playback.object.vod.0DE22BC8-73E4-462D-8AC9-8F8BC4B015E9&consumptionType=Streaming&desiredResources=Widevine2License&resourceUsage=ImmediateConsumption&videoMaterialType=Feature&userWatchSessionId=08353073-05ce-411c-9ec6-751196cca38f&deviceProtocolOverride=Https&deviceStreamingTechnologyOverride=DASH&deviceDrmOverride=CENC&deviceBitrateAdaptationsOverride=CVBR%2CCBR&deviceHdrFormatsOverride=None&deviceVideoCodecOverride=H264&deviceVideoQualityOverride=HD&playerAttributes=%7B%22middlewareName%22%3A%22Chrome%22%2C%22middlewareVersion%22%3A%2297.0.4692.99%22%2C%22nativeApplicationName%22%3A%22Chrome%22%2C%22nativeApplicationVersion%22%3A%2297.0.4692.99%22%2C%22supportedAudioCodecs%22%3A%22AAC%22%2C%22frameRate%22%3A%22HFR%22%2C%22H264.codecLevel%22%3A%224.2%22%2C%22H265.codecLevel%22%3A%220.0%22%7D
    HEADERS:
    Accept-Encoding: gzip, deflate, br
    Accept-Language: es-ES,es;q=0.9
    Authorization: Bearer Atna|EwICIPUfWgG8wnQAtjHR9QhLjRETs1pjvC3XhGe5mAXUtcUtYfz2eOL6C-omb60azEiJyrcVBeo6LEfNVV_njjCtM_xY6cszMauK2OTBXYOmLCs6kWvtKv3odiIna7eTpWV0EZmPd5R2mLXmw59UoljUfptfq2hh9c_ughI7yk-KGMEA2FAIocdsmO0srjJxgTpTd32Z_881FbNDJz1D3v3ncdIbgvpEWXdyFA1qEnADNAO56VEfUrkiaF-Vj-oqYD_RZto
    Connection: keep-alive
    Content-Length: "6950"
    Content-Type: application/x-www-form-urlencoded
    Host: q321d2vicz2ra0.eu.api.amazonvideo.com
    Origin: https://music.amazon.es
    Referer: https://music.amazon.es/
    User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/97.0.4692.99 Safari/537.36
    ERROR
    Error 404:<br>
  28. Member
    Jan 2019
    hawaii
    wrong pssh. and lic url also
  29. Originally Posted by lomero View Post
    how to get lic url ? nothing in mpd file
  30. Member
    Jan 2019
    hawaii
    sniff http traffic
    on network tab search lic or widevine or dash
