This may just be a formatting question. I have some subtitles set to show up pretty large. What I see is a fresh subtitle line, then the completion or next element above the first rather than new line scrolling below in its place. A hard problem to describe.
If using VLC with an external subtitle the settings tabs will not give the 'smaller' option.
Alternately I use Potplayer but I'm not good at looking at the extent of its options.
Results 1 to 1 of 1
NTSC Capture Has White Line Near Top of Screen
By TazDave in forum CapturingReplies: 79Last Post: 21st Jul 2021, 05:10 -
Divide each line of text into new subtitle line
By martanius in forum SubtitleReplies: 1Last Post: 11th Apr 2021, 17:21 -
How to add a new line with same text to multiple subtitle at once?
By zyck in forum SubtitleReplies: 7Last Post: 19th Apr 2020, 09:01 -
Vdub displays black screen for DirectShow Capture, works for VFW
By skatingrocker17 in forum EditingReplies: 0Last Post: 3rd Jun 2018, 21:32 -
JVC GR-FX17 compact VHS camcorder on screen displays
By VHS-C98 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Jan 2017, 22:18
