Page 2 of 2
FirstFirst 1 2
Results 31 to 39 of 39
  1. If you want just the final "stacked" image (not the animation), there is a function FrameBlendX by riffraff42 that works significantly faster
    https://forum.doom9.org/showthread.php?p=1829133#post1829133
    ImageSource(...)
    FrameBlendX(0, "lighten", 1.0)
    ### Blend a number of frames together, up to all frames in the clip
    ##  Output framerate and duration are same as the source.
    ## @ blendfactor   - blend 'n' frames; if 1, do nothing; if <=0, blend all frames
    ## @ blend_mode    - see Overlay
    ## @ blend_opacity - see Overlay
    ## Examples
    ## | ## average of all frames
    ## | FrameBlendX(0, "blend", 0.5)
    ## | ## streak effect (with the right source)
    ## | FrameBlendX(0, "lighten", 1.0)
    function FrameBlendX(clip C, int blendfactor, string blend_mode, float blend_opacity)
        C
        limit = (blendfactor<=0) ? 1 : Max(1, FrameCount/blendfactor)
        while (FrameCount>limit) {
            Overlay(SelectEven, SelectOdd, mode=blend_mode, opacity=blend_opacity)
        ConvertFPS(C)
        return (blendfactor==1) ? C : Last
    Apr 2020
    Canada
    That's interesting. You're the king of my day for sure.
    But i'll keep the animation to "study" where planes fly and doesn't fly by often.
    Well, Now I have another problem but it's not related to avisynth at all...
    when capturing flightradar24.com, the thing expire every 30 minutes and there's some ad and a layer of shade for the night that I all disable via the element inspector, but since the thing expire after 30 imutes, I have to refresh and re-hide unwanted elements.
    I know that's something you can script in GreaseMonkey... but I have no clue of how this works...
    I have to see if there is some forums for that niche application... I know a lot of people use such script to modifiy the apparence of the website they often look at...
    Well.
    Thanks again for everything!
    Tommy
    Apr 2020
    Canada
    A friend helped me with the webpage tweaking with a script but I have another concern with our avs stuff...
    For some reason, after I tweaked the stuff to make the planes smaller on the map, the script doesn't want to stretch lines and nothing moves. If I set the function to 1,0,0
    the planes moves like a movie with no stretching. Is there a difference threshold somewhere so since the places are smaller it doesn't' detect them??
    Here's a few jpeg that cause me a problem.
  4. Originally Posted by zikmen View Post
    "lighten" for this overlay blend mode scenario works when the overlaid image is lighter than the base image. Since the BG is brighter than the planes on those recent images, the planes disappear as expected
    If the planes are bright, then using "lighten" mode should accumulate them, leaving the BG intact
    loop(1,0,0) does nothing. It means loop frame zero to zero once . Which does nothing : 0,1,2,3...
    Loop(2,0,0) means show frame zero twice, so it would go 0,0,1,2,3...
    The reason for the offset is you're overlaying the previous frame with current frame. The offset is required to see something. If you overlay the same frame, it looks like the original sequence
    http://avisynth.nl/index.php/Loop
    Apr 2020
    Canada
    So if I simply lower the map brightness with my css script a bit so the planes are brighter than the BG it will work again!
    I'll try that right away!
    Apr 2018
    Croatia
    I would use lagfun filter with ffmpeg.
  7. Originally Posted by zikmen View Post
    Or use darken rather than lighten.
    imagesource("%05d.jpg", 1, 20, fps=30)
    main=last
    b=blankclip(main, color=color_white)
    ScriptClip("""
      b = b.Loop(2,0,0).Overlay(last, mode="darken")
      return b
    Apr 2020
    Canada
    Ok thanks jagabo, i'll give that a try in the next round raising up again the brightnes. That might in deed define better the planes because they have a outline of 1 black px that obbiously disapear with lighten... but I'm not sure then if the map will fill with black stuff i won't want...
    To try!
    For now I have lowered the brightness of the map to 80% with css and that works great, I adjust the thing up a bit later on with a simple level filter and that suits my needs quite good.
    I'm at 1700 frames captured this morning, 2 frames a minute real time, I've never been that far yet. I'm curious to assemble that over a whole week and see if there will stay some pieces of air where no planes fly by!
    Thanks again!
    I'll drop the final result over here for sure!
  9. Originally Posted by zikmen View Post
    Where is that black stuff going to come from?
