Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 73
  1. Hi. I'm trying to download this video here https://m4uhd.tv/watch-movie-bad-turn-worse-2013-4354.html , but I still haven't figured it out how yet... I've tried to use the VideoDownloadHelper extension for Firefox, but if I try to grab the link(s) and download it, all I get is only some very short parts of the movie (in fact the files are only like 1-2 mbs)!
    Any idea of how to download from a site like that?
    Thanks in advance.
  2. The link may change soon...
    https://www2182.ff-05.com/token=uA2_zK27L9Rj3eKWqXe3tA/1639526332/109.236.0.0/66/5/36/...1a365-720p.mp4
    I used the HTTP Header Live plugin for Firefox to get the link.
  3. If you use network sniffer, you'll see an api call with a response of seemingly random letters that are actually the partial links to get all the files. Use a mass downloader and join them with ffmpeg or something.
  4. Originally Posted by jagabo View Post
    Yeah, it doesn't seem to work already... Could you tell me how you got that link? I downloaded that plugin, but I can't find url similar to that one you posted when I visit the page...
  5. here is how it's done.
    First thank you jagabo. @[ss]vegeta it's much simpler than your suggestion, which is good by the way.
    1) As jagabo pointed out ... install HTTP Header Live plugin for Firefox
    2) Go to link https://m4uhd.tv/watch-movie-bad-turn-worse-2013-4354.html and play the movie. Select the resolution that you desire. Restart movie with desired resolution
    3) All the while the plugin will be running
    4) From plugin select save
    5) Open saved log in text editor and search for .ff- and select the https://www ... .ff- with the desired resolution.
    6) enter url in browser and select download from the 3 vertical dots
    Enjoy
  6. Originally Posted by jack_666 View Post
    Enjoy
    First of all, thanks for the answer. I did try to do what you say, but when I search for that .ff- element in the txt file (that I create by clicking on "Save file" in the plugin window), I just can't find it
  7. I don't think the server is always https://www2182.ff-05.com/... Try searching for 720p, 360p, mp4, etc. By the way, I switched to the #Q-F server to get my link.
  8. Originally Posted by jagabo View Post
    Nothing... I did try those too, but I just can't find anything. I don't know if there's something wrong with how I get the txt file... I mean, I start the video and click on the plugin icon at the top right in Firefox, then I click on "Save file"...
  9. Nothing... I did try those too, but I just can't find anything. I don't know if there's something wrong with how I get the txt file... I mean, I start the video and click on the plugin icon at the top right in Firefox, then I click on "Save file"...
    Did you play the movie? Trying playing the movie for say 5 minutes. After playing the movie for 5 minutes in the desired resolution, click save and inspect the txt file
    If still unable to detect mp4, zip up the text file and upload somewhere and send the download link.
  10. Originally Posted by Mistral91 View Post
    No, the plugin only shows urls that are accessed after it has been opened. You should open the plugin then refresh the page and play the video.
    Jan 2019
    hawaii
    more easy.
    install user-agent into your browser. choose from mobile: android tablet/chrome87
    then get m3u8
    yt-dlp https://m3u8-plhq.playm4u.xyz/m3u8/v3/5/5f178b9f6fcdd6224e2ae02a/1639573307/912ce289da5e0d2d70efe7913eb68257.m3u8
  12. Originally Posted by jack_666 View Post
    Ok, I tried to open the plugin, play the movie for 5 good minutes but still nothing... Here's the txt: https://file.io/X1XzpQRujww3
  13. Looks like the link gas expired... I'll post a new one here: https://ufile.io/xjfbwyn5
    Jan 2019
    hawaii
    https://www2182.ff-05.com/token=iJ4vxtCc2ze4Oz87E8Uo1w/1639605873/151.44.0.0/66/5/36/4de31cebdf3ae6a07d909a2553c1a365-720p.mp4
    download fast. link expired soon.
    and not easy to get link.
    you need to try and try many times, at the end you find it ...
    and anyway when you get link with HTTP Header Live also IDM get link and work fine. but need to play video many time
  15. Originally Posted by lomero View Post
    403 forbidden, 1 minute after you posted
    Jan 2019
    hawaii
    yes. more easy my method above, get m3u8 and download with yt-dlp
  17. Originally Posted by lomero View Post
    Yeah, it already doesn't work. I don't know what you mean by "try many times", but I've tried playing the video a few times and never managed to get any valid link!
  18. Originally Posted by lomero View Post
    I appreciate the answer, but to be honest I don't even know what you're talking about... I know it's not your fault, but that doesn't quite seem an "easy" method for me
    Nov 2015
    Campuchia - Sapoche
    try with method at post#11 it work fine
  20. Originally Posted by therain View Post
    I tried to install that user-agent, but I can't find those options, and I don't know how you get to that screenshot!
    Nov 2015
    Campuchia - Sapoche
    try with google for how to........
    https://www.youtube.com/watch?v=EhXUCPm3q30
  22. Originally Posted by therain View Post
    That's what I did, but I can't find the "mobile: android tablet/chrome87" part... I can only select Google Android 7 (in the Mobile Device section), but no chrome87 or anything like that (if I click on Chrome below, it automatically deselects Android)!
  23. Member
    Nov 2015
    Campuchia - Sapoche
    you sure ? Stop here, just try and don't ask more...see my pic for more detail
  24. It's a completely different window, LOL
    [Attachment 62378 - Click to enlarge]
  25. Member
    Nov 2015
    Campuchia - Sapoche
    Do you think or try this method at post#11 ? It using for firefox and it have "mobile: android tablet/chrome87" same my pic ?
    you always ask more and more.......but not tried and it right or not for your pic ?
  26. Originally Posted by therain View Post
    What?
  27. Make sure mp4 is in the "Include Text" option box of HTTP Header Live:
    [Attachment 62380 - Click to enlarge]
    With HTTP Header Live open switch to the #Q-F server to get the mp4 link:
    [Attachment 62379 - Click to enlarge]
  28. Originally Posted by jagabo View Post
    Thank you, I finally did it. The problem is that I didn't switch to the #Q-F option... As soon as I did, I found the link! Btw, what does that stands for? And what's the difference with #M? Thank you again!
  29. #M probably stands for m4uhd.tv. The F in #Q-F may refer to the fembed.com video platform. In any case it's just two different servers hosting the files.
  30. Member
    Jan 2019
    hawaii
    @Mistral91
    <I don't know what you mean by "try many times"....>
    get video isn't immediate. need to reload page several times to get video link
    at your post#24 is different, yes. we have different extension for FF with same name but different.
    to this you don't have what i said in my post#11
    try to find with User-Agent Switcher by Kuri Schlarb
