I have an '*.avi' file which has a yellow tinge to it, like not enough bright? light?
Is there software to brighten up the image?
Its not really worth $pending money on, so, freeware or trialware would suit the bill.
-corne-
Yes, no, maybe, I don't know, Can you repeat the question?
AviDemux also as some color adjustment filters.
Basically nearly every free tool which does video filtering has options for color adjustment.
Avisynth/Vapoursynth could be used for some more advanced color adjustments, but you probably would need to post a sample for detailed advice.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Thanks, , , ,
SEGA MEGA DRIVE strip of colored pixels on bottom screen
By retroborg in forum Off topicReplies: 0Last Post: 11th Oct 2020, 13:01 -
Colored Subtitles for YouTube?
By karabiner99k in forum Newbie / General discussionsReplies: 0Last Post: 14th Apr 2020, 05:04 -
Converting (Blu-ray) sup file to srt (karaoke colored subtitles)
By earl_bstard in forum SubtitleReplies: 2Last Post: 15th Feb 2020, 23:02 -
How to make larger colored subs?
By Paultx in forum Newbie / General discussionsReplies: 9Last Post: 23rd May 2019, 11:24 -
multi-colored dialogue
By tamotsumono in forum SubtitleReplies: 11Last Post: 3rd Feb 2018, 10:15
