fortunately I found in basement a JVC hr s9600, I would like to rip my home VHS tapes, can you help me in choosing what else I need. my thoughts after research:
1. JVC HR s9600 + Canon HV20 + PCIE Firewire card + upscaling in post prod software
2. JVC HR s9600 + DMR-EZ48V and after rip DVD
3. JVC HR s9600 + advc 110 + Blackmagic Intensity Pro 4K + upscaling in post prod software
4. JVC HR s9600 + mini upscaler rca to hdmi (15-30$) + hdmi grabber
any other options ? suggestions?
Results 1 to 10 of 10
HDMI / upscale = bad idea
HV20? Does it encode DV? I didn't think so.
ADVC110 passable for PAL
JVC 9600
> some form of frame TBC (ES15 at worst, though non-TBC frame sync with line TBC)
> quality SD analog capture card
More ideal is an actual TBC. Not-really sorta-kinda non-TBCs have issues.
Remember: Buy it, use it, resell it.Want my help? Ask here! (not via PM!)
ES20 does not have a line TBC.
ES10 does (strong+crippled).Want my help? Ask here! (not via PM!)
do any of you have good experience with capture NTSC VHS on PAL VCR?
and how does this process look like? what devices do you use for this? -
PAL VHS players output PAL60 when playing NTSC tapes. That is a hybrid signal with NTSC timing (59.94 fields per second) and chroma on PAL 4.43 MHz carrier (not NTSC 3.58 MHz chroma carrier).
https://en.wikipedia.org/wiki/PAL#Home_devices_and_PAL_60
Most capture devices don't work support PAL60 and deliver a greyscale image (because they're looking for colors in the wrong place). Be sure to get a capture device that supports PAL60. Then capture at 720x480, 29.97 frames per second. -
It will be about the same as capturing from an NTSC VHS deck. But the best quality for VHS requires an S-VHS deck with line time base corrector. S-VHS decks in good working condition cost about US$500 these days. Second best would be good VHS deck and a DVD recorder with line TBC in passthrough mode.
I don't know much about them myself. Maybe someone else will have some recommendations.
http://www.digitalfaq.com/forum/video-restore/1567-vcr-buying-guide.html
Of course, the one that's in better shape may be better even though it originally wasn't as good as the other.
VHS Digitization in 2019
By Tig_ in forum Capturing and VCRReplies: 50Last Post: 2nd Jul 2021, 13:55 -
Hardware .vs software upscaling
By Santuzzu in forum Newbie / General discussionsReplies: 24Last Post: 2nd Apr 2021, 21:00 -
VHS digitization service recommendation
By P-Rock in forum Capturing and VCRReplies: 2Last Post: 20th Sep 2020, 12:37 -
Outsourcing VHS digitization: Costs?
By Knocks in forum Capturing and VCRReplies: 5Last Post: 18th Aug 2019, 16:41 -
Capturing VHS with TBC setup (Suggestions/Confirmation wanted)
By crissrudd4554 in forum Capturing and VCRReplies: 2Last Post: 10th May 2019, 00:32
