I have captured HI8 Videos (720x576) and have deinterlaced them with QGTMC. But the PAR ratio is 5:4 istead of 4:3
Now when im working in davinci resolve i can save videos in 4:3 only which gives me smaller video size.
How to fix the Pixel Ascpect Ratio? Im using avisynth+ too
Pixel Aspect Ratio (PAR) is not actually the correct term here. It is Display Aspect Ratio (DAR). Your reporting program is assuming square pixels (PAR = 1:1) whereas they originally were not.
I am not familiar with your editor but I guess it is converting to 720*540 to give you the 4:3 DAR. But you really should not be fixed with that and can use any ratio to give you a true 4:3 eg 1440*1080. Both of these are ideal for 1920*1080 displays. FYI the true display for 720*576 would be 768*576 -
Load your final video into clever FFmpeg-GUI, click main, click Change Video DAR, select the desired DAR, click Change DAR, done.
[Attachment 62337 - Click to enlarge]
fix wrong deinterlace (BFF, not TFF)
By taigi in forum Video ConversionReplies: 3Last Post: 27th May 2021, 06:46 -
restore PAR?
By taigi in forum Video ConversionReplies: 22Last Post: 20th May 2021, 23:30 -
What app can trim v210 codec in mov container and also retain PAR?
By digicube in forum EditingReplies: 3Last Post: 16th Apr 2021, 14:29 -
Lots of mp4 videos with wrong language metadata, bulk tool to fix?
By wkearney99 in forum Newbie / General discussionsReplies: 13Last Post: 22nd May 2017, 07:37 -
DVD's PAR and output display size explanation in Handbrake
By Superfrank in forum Video ConversionReplies: 3Last Post: 11th Feb 2017, 17:27
