Hi. This is the page for Avisynth+ 3.7.0:
https://www.videohelp.com/software/AviSynth-Plus
The screenshot on the right hand side shows the user being given a choice between x86 and x64.
Down the page under 'All features' it says: "64-bit version available".
I downloaded from the link but I only get the x86 version. Where can I get the download that allows you to choose between x86 amd x64 as per the screenshot?
Thank you.
Did you start the installer? Since normally it lets you select - like the screenshot shows - whether the x86 and/or the x64 components get installed.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Aha.. I was thrown by this:
[Attachment 62316 - Click to enlarge]
which I took to mean it was x86 only. But keep pressing Next and all is well. Thanks, Selur. -
Avisynth 64bit + mencoder/mplayer ?
By Selur in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2020, 03:38 -
How to use 64bit avisynth plugins in vapoursynth with the Eval function?
By danfgtn in forum Newbie / General discussionsReplies: 3Last Post: 18th Feb 2019, 14:08 -
64bit DebugMode FrameServer
By wwaag in forum EditingReplies: 7Last Post: 7th Dec 2018, 05:09 -
VFR TO CFR in avisynth 64bit and LSMASH source^?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 22nd Oct 2017, 06:28 -
does exist a 64bit version of TWriteAVI for avisynth?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 29th Aug 2017, 03:59
