I digitized a 35 year old VHS cassette and the sound is very poor. Here is a download link to a 2-minute sample audio file of what the sound is like:
https://vocaroo.com/1oPyR5Ub429n
I've tried various settings in Sound Forge as per tips on YouTube but all they seem to do is make the sound even worse! Is there anything that can (easily) be done to at least improve the sound somewhat, at least to make it sound more clear / less murky but without adding other unwanted noises, and if so how?
Results 1 to 11 of 11
You should start be recording as uncompressed PCM, not lossy, low bitrate, mp3. If the tape has a HiFi track record that instead of the low bandwidth, mono, linear track.
follow jagabo advice, you can try to use exciter to make audio brighter - for example https://ffmpeg.org/ffmpeg-filters.html#aexciter
Upload a sample of the wav file here, or zip it up and use the external host.
Please try this download for a 2-minute sample of uncompressed WAV of the sound from the tape: https://easyupload.io/gbh1g9
The tape sounds absolutely horrible, even when played on the VCR to the TV. -
From my perspective quality is OK, knowing audio source more than good (any processing in between?) - exciter you need to do some experiments - not sure what is your expectations, seem there are some signal above 8kHz at least on spectrum analyzer, also noise floor seem to be dynamic (so from my perspective there is some processing obviously)
Code:@ffmpeg.exe -i sample.wav -vn -af "pan=mono|FC < 1FL + 1FR,asuperstop=centerf=15625:order=6:qfactor=100,aexciter=amount=8:blend=0:listen=0" sample_.wav
Maybe something like this:
Code:ffmpeg -y -i sample.wav -af aexciter=freq=3000:level_out=2:amount=2:drive=8.5:ceil=20000 output.wav
The results from your code are really good. Thank you so much. I have applied the same code to the full file. One question though, the original WAV (100 minutes long) is 1.60 Gb in size, but the result ends up at 1.07Gb. Do you know why the reworked WAV is 500 Mb smaller?
Oh, I didn't notice the size difference. The source was 24 bit, the new file is 16 bit. If you want 24 bit output:
Code:ffmpeg -i sample.wav -af aexciter=freq=3000:level_out=2:amount=2:drive=8.5:ceil=20000 -acodec pcm_s24le output24.wav
Improve quality of a mp4 file (720p)
By VideoLover in forum Newbie / General discussionsReplies: 2Last Post: 25th Mar 2020, 20:00 -
LosslessCut gives input file sound only - no video
By FredVH in forum EditingReplies: 0Last Post: 27th Oct 2019, 18:39 -
Error Hecv file without sound
By ctimict in forum AudioReplies: 1Last Post: 27th Feb 2019, 12:27 -
DVD Architect 5.0 TS file has no sound
By crissrudd4554 in forum Authoring (DVD)Replies: 2Last Post: 20th Nov 2018, 07:31 -
Converting video file with FLAC sound
By GiesbertsN in forum Video ConversionReplies: 7Last Post: 15th Mar 2018, 12:50
