I know that this is a very frequent question here but I have tried many of the steps and most of them don't work on a mac. I am not looking for a player that has HDR tone mapping such as MadVR. I have a 4k remux that I want to convert to SDR. I have tried using Handbrake such as this guide reccomends: https://www.reddit.com/r/handbrake/comments/mom65d/4k_hdr_to_1080p_sdr_question/.
The problem is that Handbrake conversion is very lossy and I want a lossles conversion which only changes color space. There is also an FFMPEG tutorial: https://www.reddit.com/r/PleX/comments/h8afyx/how_to_convert_4k_movies_with_washed_out_colors/.
This tutorial does not work with Mac and I don't know if it lossless. Is there anything I can do to achieve a lossless or near lossless conversion?
Computer Specs:
Macbook Pro 2017(15 inch, 2880 x 1800) , macOS Big Sur 11.6, 2,9 GHz Quad-Core Intel Core i7, 16 GB 2133 MHz LPDDR3 Ram, 500gb storage, Intel HD Graphics 630 1536 MB
Perhaps ffmpeg can be option for you, just download newest possible ffmpeg for your OS and try to follow command line provided here:
https://raw.githubusercontent.com/benjaminburkhardt/convert-hdr-to-sdr/main/convert_hdr_to_sdr.sh
https://raw.githubusercontent.com/awawis/ffmpeg-HDR-to-SDR-conversion/master/4k%20HDR%...0to%204K%20SDRCode:"ffmpeg -i filename -map 0:v:0 -map 0:a:0? -aspect 16:9 -vf zscale=t=linear:npl=100,format=gbrpf32le,zscale=p=bt709,tonemap=tonemap=hable:desat=0,zscale=t=bt709:m=bt709:r=tv,format=yuv420p -c:v libx264 -preset fast -profile:v high -crf 18 -c:a aac -b:a 192k -y "filename_converted"
or hereCode:ffmpeg.exe -i "filename" -vf zscale=t=linear:npl=100,format=gbrpf32le,zscale=p=bt709,tonemap=tonemap=hable:desat=2,zscale=t=bt709:m=bt709:r=tv,format=yuv420p -c:v libx264 -crf 22 -preset veryfast "filename_converted"
https://stackoverflow.com/questions/61460247/10bit-hdr-to-10bit-sdr-conversion-with-ffmpeg
Converting UHD HDR to SDR?
By tommy2010 in forum Blu-ray RippingReplies: 9Last Post: 19th Mar 2021, 04:12 -
Problems converting 4K HEVC HDR-10bit videos to 4K SDR H.264
By Emy78 in forum Video ConversionReplies: 8Last Post: 26th Nov 2020, 23:18 -
Convert .MTS files from a Sony HDR TD20 to SBS (or split L+R) on Mac ???
By restlessman in forum Video ConversionReplies: 2Last Post: 17th Nov 2020, 12:34 -
CONVERT 4K HDR (.mkv) TO 4K SDR (.mp4) - Who helps me?
By Alberto78 in forum Video ConversionReplies: 6Last Post: 7th Mar 2020, 08:38 -
HDR to SDR Avisynth+
By tommy2010 in forum Video ConversionReplies: 2Last Post: 7th Jan 2018, 17:51
