How the hell am I supposed to open/convert these clips and jpegs?Code:General Complete name : C:\Users\zabav\Music\Al\2003 - Poodle Hat\CDplus\ALECD.mov Format : QuickTime Format/Info : Original Apple specifications Format settings : Compressed header File size : 138 MiB Duration : 1 h 42 min Overall bit rate : 187 kb/s Encoded date : UTC 2003-04-23 17:54:23 Tagged date : UTC 2003-04-23 17:54:46 Writing application : Made with LiveStage Pro Writing library : Apple QuickTime Video #1 ID : 1 Format : Sorenson 3 Codec ID : SVQ3 Codec ID/Info : Sorenson Media Video 3 (Apple QuickTime 5) Duration : 8 min 35 s Source duration : 8 min 30 s Source_Duration_LastFrame : -15 ms Width : 360 pixels Height : 240 pixels Display aspect ratio : 3:2 Frame rate mode : Constant Frame rate : 24.000 FPS Source stream size : 66.4 MiB (48%) Title : Video 1 Language : English Encoded date : UTC 2003-04-23 17:53:38 Tagged date : UTC 2003-04-23 17:54:46 Video #2 ID : 13 Format : JPEG Codec ID : jpeg Duration : 8 min 38 s Source duration : 8 min 33 s Bit rate : 4 295 b/s Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 0.002 FPS Color space : YUV Chroma subsampling : 4:4:4 Bit depth : 8 bits Compression mode : Lossy Bits/(Pixel*Frame) : 6.991 Stream size : 262 KiB (0%) Source stream size : 262 KiB (0%) Title : movieback Language : English Encoded date : UTC 2003-04-23 17:54:04 Tagged date : UTC 2003-04-23 17:54:46 Video #3 ID : 14 Format : JPEG Codec ID : jpeg Duration : 1 h 19 min Bit rate : 652 b/s Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 0.000 FPS Color space : YUV Chroma subsampling : 4:4:4 Bit depth : 8 bits Compression mode : Lossy Stream size : 377 KiB (0%) Title : skinfront Language : English Encoded date : UTC 2003-04-23 17:54:04 Tagged date : UTC 2003-04-23 17:54:46 Video #4 ID : 16 Format : JPEG Codec ID : jpeg Duration : 8 min 45 s Source duration : 9 s 10 ms Bit rate : 217 kb/s Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 0.111 FPS Color space : YUV Chroma subsampling : 4:4:4 Bit depth : 8 bits Compression mode : Lossy Bits/(Pixel*Frame) : 6.354 Stream size : 13.5 MiB (10%) Source stream size : 238 KiB (0%) Title : photoback Language : English Encoded date : UTC 2003-04-23 17:54:04 Tagged date : UTC 2003-04-23 17:54:46 Video #5 ID : 17 Format : JPEG Codec ID : jpeg Duration : 47 min 17 s Source duration : 38 min 30 s Bit rate : 1 035 b/s Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 0.000 FPS Color space : YUV Chroma subsampling : 4:4:4 Bit depth : 8 bits Compression mode : Lossy Stream size : 359 KiB (0%) Source stream size : 359 KiB (0%) Title : mixeswall Language : English Encoded date : UTC 2003-04-23 17:54:04 Tagged date : UTC 2003-04-23 17:54:46 Video #6 ID : 18 Format : JPEG Codec ID : jpeg Duration : 1 h 42 min Source duration : 55 min 33 s Bit rate : 960 b/s Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 0.000 FPS Color space : YUV Chroma subsampling : 4:4:4 Bit depth : 8 bits Compression mode : Lossy Stream size : 723 KiB (1%) Source stream size : 362 KiB (0%) Title : lyricswall Language : English Encoded date : UTC 2003-04-23 17:54:04 Tagged date : UTC 2003-04-23 17:54:46 Video #7 ID : 19 Format : JPEG Codec ID : jpeg Duration : 1 h 42 min Source duration : 3 s 450 ms Bit rate : 907 kb/s Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 0.290 FPS Color space : YUV Chroma subsampling : 4:4:4 Bit depth : 8 bits Compression mode : Lossy Bits/(Pixel*Frame) : 10.176 Stream size : 667 MiB Source stream size : 382 KiB (0%) Title : credits Language : English Encoded date : UTC 2003-04-23 17:54:04 Tagged date : UTC 2003-04-23 17:54:46 Video #8 ID : 25 Format : JPEG Codec ID : jpeg Duration : 5 s 500 ms Source duration : 500 ms Bit rate : 2 332 kb/s Width : 360 pixels Height : 240 pixels Display aspect ratio : 3:2 Frame rate mode : Constant Frame rate : 2.000 FPS Color space : YUV Chroma subsampling : 4:4:4 Bit depth : 8 bits Compression mode : Lossy Bits/(Pixel*Frame) : 13.493 Stream size : 1.53 MiB (1%) Source stream size : 142 KiB (0%) Title : moviead Language : English Encoded date : UTC 2003-04-23 17:54:05 Tagged date : UTC 2003-04-23 17:54:46 Video #9 ID : 59 Format : RLE Format/Info : Run-length encoding Codec ID : rle Duration : 1 h 42 min Bit rate : 0 b/s Width : 32 pixels Height : 2 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 0.000 FPS Color space : RGBA Bit depth : 8 bits Stream size : 29.0 Bytes (0%) Title : LSP Background Language : English Encoded date : UTC 2003-04-23 17:54:21 Tagged date : UTC 2003-04-23 17:54:46 Video #10 ID : 61 Format : JPEG Codec ID : jpeg Duration : 1 h 42 min Bit rate : 500 b/s Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 0.000 FPS Color space : YUV Chroma subsampling : 4:4:4 Bit depth : 8 bits Compression mode : Lossy Stream size : 377 KiB (0%) Title : Background for Skin FT 1 Language : English Encoded date : UTC 2003-04-23 17:54:21 Tagged date : UTC 2003-04-23 17:54:46 Audio ID : 2 Format : ADPCM Format settings : IMA Codec ID : ima4 Duration : 8 min 35 s Source duration : 8 min 30 s Bit rate mode : Constant Bit rate : 352.8 kb/s Channel(s) : 2 channels Sampling rate : 44.1 kHz Stream size : 21.7 MiB (16%) Source stream size : 22.8 MiB (17%) Title : Sound 1 Language : English Encoded date : UTC 2003-04-23 17:53:48 Tagged date : UTC 2003-04-23 17:54:46 Other #1 Type : flsh Duration : 12 min 27 s Source duration : 3 min 37 s Stream size : 4.92 MiB Source stream size : 1.64 MiB Title : mix1a.swf Other #2 Type : flsh Duration : 16 min 7 s Source duration : 3 min 39 s Stream size : 6.64 MiB Source stream size : 1.66 MiB Title : mix2a.swf Other #3 Type : flsh Duration : 22 min 23 s Source duration : 6 min 15 s Stream size : 11.3 MiB Source stream size : 2.83 MiB Title : mix3a.swf Other #4 Type : flsh Duration : 27 min 18 s Source duration : 4 min 54 s Stream size : 13.3 MiB Source stream size : 2.22 MiB Title : mix4a.swf Other #5 Type : flsh Duration : 29 min 47 s Source duration : 2 min 28 s Stream size : 13.5 MiB Source stream size : 1.12 MiB Title : mix5a.swf Other #6 Type : flsh Duration : 47 min 16 s Source duration : 38 min 29 s Stream size : 29.5 KiB Source stream size : 29.5 KiB Title : mixbuttons2.swf Other #7 Type : flsh Duration : 38 min 45 s Source duration : 8 min 57 s Stream size : 16.1 MiB Source stream size : 4.03 MiB Title : mix6a.swf Other #8 Type : flsh Duration : 42 min 23 s Source duration : 3 min 37 s Stream size : 19.7 MiB Source stream size : 1.64 MiB Title : mix7a.swf Other #9 Type : flsh Duration : 47 min 16 s Source duration : 4 min 52 s Stream size : 22.0 MiB Source stream size : 2.20 MiB Title : mix8a.swf Other #10 Type : flsh Duration : 48 min 9 s Source duration : 9 s 455 ms Stream size : 8.35 MiB Source stream size : 27.9 KiB Title : lyricchoices2.swf Other #11 Type : sprt Duration : 48 min 9 s Source duration : 48 min 4 s Stream size : 6.45 KiB Source stream size : 6.45 KiB Title : MainBtn Other #12 Type : sprt Duration : 1 h 42 min Source duration : 54 min 41 s Stream size : 12.9 KiB Source stream size : 6.45 KiB Title : Main2btn Other #13 Type : sprt Duration : 1 h 42 min Source duration : 54 min 41 s Stream size : 13.3 KiB Source stream size : 6.64 KiB Title : lyricsbtn Other #14 Type : sprt Duration : 1 h 42 min Source duration : 4 s 0 ms Stream size : 9.72 MiB Source stream size : 6.44 KiB Title : main3btn Other #15 Type : sprt Duration : 5 s 0 ms Title : credits Other #16 Type : sprt Duration : 1 h 42 min Source duration : 3 s 450 ms Stream size : 114 MiB Source stream size : 65.1 KiB Title : webbtn Other #17 Type : flsh Duration : 8 min 45 s Source duration : 9 s 0 ms Stream size : 146 MiB Source stream size : 2.51 MiB Title : PhotoFinal.swf Other #18 Type : flsh Duration : 4 s 0 ms Title : easteregg2.swf Other #19 Type : flsh Duration : 52 min 29 s Source duration : 4 min 18 s Stream size : 24.8 MiB Source stream size : 2.07 MiB Title : PotatoFin.swf Other #20 Type : flsh Duration : 56 min 13 s Source duration : 3 min 43 s Stream size : 27.0 MiB Source stream size : 1.80 MiB Title : HardwareFin.swf Other #21 Type : flsh Duration : 59 min 25 s Source duration : 3 min 10 s Stream size : 29.0 MiB Source stream size : 1.52 MiB Title : TrashFin.swf Other #22 Type : flsh Duration : 1 h 3 min Source duration : 3 min 37 s Stream size : 28.6 MiB Source stream size : 1.68 MiB Title : LeperFin.swf Other #23 Type : flsh Duration : 1 h 8 min Source duration : 5 min 2 s Stream size : 33.7 MiB Source stream size : 2.41 MiB Title : AWBPFin.swf Other #24 Type : flsh Duration : 1 h 14 min Source duration : 6 min 14 s Stream size : 35.1 MiB Source stream size : 2.93 MiB Title : WannaBFin.swf Other #25 Type : flsh Duration : 1 h 18 min Source duration : 3 min 39 s Stream size : 36.1 MiB Source stream size : 1.72 MiB Title : ComplicatedFin.swf Other #26 Type : flsh Duration : 1 h 22 min Source duration : 4 min 51 s Stream size : 38.8 MiB Source stream size : 2.28 MiB Title : WhyDoesFin.swf Other #27 Type : flsh Duration : 1 h 27 min Source duration : 4 min 50 s Stream size : 40.5 MiB Source stream size : 2.25 MiB Title : SuperheroFin.swf Other #28 Type : flsh Duration : 1 h 30 min Source duration : 2 min 29 s Stream size : 41.5 MiB Source stream size : 1.15 MiB Title : BobFin.swf Other #29 Type : flsh Duration : 1 h 33 min Source duration : 3 min 36 s Stream size : 43.4 MiB Source stream size : 1.67 MiB Title : EbayFin.swf Other #30 Type : flsh Duration : 1 h 42 min Source duration : 8 min 55 s Stream size : 50.1 MiB Source stream size : 4.18 MiB Title : GeniusFin.swf Other #31 Type : sprt Duration : 5 s 2 ms Source duration : 1 s 0 ms Stream size : 4.82 KiB Source stream size : 988 Bytes Title : navstop Other #32 Type : sprt Duration : 8 min 46 s Source duration : 590 ms Stream size : 872 KiB Source stream size : 1 001 Bytes Title : photostop Other #33 Type : sprt Duration : 48 min 9 s Source duration : 333 ms Stream size : 8.38 MiB Source stream size : 1 013 Bytes Title : lyricstop Other #34 Type : sprt Duration : 52 min 29 s Source duration : 715 ms Stream size : 31.4 MiB Source stream size : 7.29 KiB Title : Sprite 13 Other #35 Type : sprt Duration : 56 min 14 s Source duration : 360 ms Stream size : 66.8 MiB Source stream size : 7.29 KiB Title : Sprite 14 Other #36 Type : sprt Duration : 59 min 25 s Source duration : 232 ms Stream size : 110 MiB Source stream size : 7.29 KiB Title : Sprite 15 Other #37 Type : sprt Duration : 1 h 3 min Source duration : 1 s 0 ms Stream size : 27.0 MiB Source stream size : 7.29 KiB Title : Sprite 16 Other #38 Type : sprt Duration : 1 h 8 min Source duration : 240 ms Stream size : 121 MiB Source stream size : 7.29 KiB Title : Sprite 17 Other #39 Type : sprt Duration : 1 h 14 min Source duration : 650 ms Stream size : 48.9 MiB Source stream size : 7.29 KiB Title : Sprite 18 Other #40 Type : sprt Duration : 1 h 18 min Source duration : 400 ms Stream size : 83.4 MiB Source stream size : 7.29 KiB Title : Sprite 19 Other #41 Type : sprt Duration : 1 h 22 min Source duration : 867 ms Stream size : 40.9 MiB Source stream size : 7.29 KiB Title : Sprite 20 Other #42 Type : sprt Duration : 1 h 27 min Source duration : 117 ms Stream size : 322 MiB Source stream size : 7.29 KiB Title : Sprite 21 Other #43 Type : sprt Duration : 1 h 30 min Source duration : 117 ms Stream size : 331 MiB Source stream size : 7.29 KiB Title : Sprite 22 Other #44 Type : sprt Duration : 1 h 33 min Source duration : 688 ms Stream size : 58.3 MiB Source stream size : 7.29 KiB Title : Sprite 23 Other #45 Type : sprt Duration : 1 h 42 min Source duration : 1 s 0 ms Stream size : 44.0 MiB Source stream size : 7.29 KiB Title : Sprite 24 Other #46 Type : flsh Duration : 8 min 35 s Source duration : 8 min 30 s Stream size : 679 Bytes Source stream size : 679 Bytes Title : movcontrols2.swf Other #47 Type : flsh Duration : 5 s 0 ms Title : navbuttons2.swf Other #48 Type : sprt Duration : 47 min 16 s Source duration : 715 ms Stream size : 35.6 MiB Source stream size : 9.20 KiB Title : mixstop Other #49 Type : sprt Duration : 8 min 36 s Source duration : 667 ms Stream size : 5.51 MiB Source stream size : 7.28 KiB Title : moviehold Other #50 Type : skin Duration : 3 ms Bit rate mode : Variable Other #51 Type : sprt Duration : 1 h 42 min Title : Buttons for Skin FT 1
That is a Flash format of the original meaning/kind. IOW, it is an animation with sprites, etc. Not normal video. Using regular tools, you will only be able to get those few static backgrounds.
If you want the whole thing you will need to use Macromedia/Adobe player tools and "play" it, while simultaneously screen recording.
Scott -
I doubt Flash will work, LiveStage Pro basically can create something like PowerPoint, where some suff is shown only on user interaction etc. iirc they named it " QuickTime interactive" or QTi.
There usually isn't a simple way to convert something like that into a video,... your best bet is probaably to play them im Quicktime and navigate the content you want while doing screen capturing.users currently on my ignore list: deadrats, Stears555, marcorocchini
Multiple video tracks in MP4
By the_steve_randolph in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2021, 10:47 -
Identifying Video with Multiple Audio Tracks
By bigcarp22 in forum Newbie / General discussionsReplies: 2Last Post: 27th Aug 2020, 06:02 -
Find All Video Files with Multiple Sub Tracks
By koberulz in forum Newbie / General discussionsReplies: 7Last Post: 19th May 2020, 12:48 -
Video edition with multiple audio tracks.
By djdan in forum Newbie / General discussionsReplies: 0Last Post: 18th Nov 2019, 16:14 -
Muxing a video with multiple video tracks/angles
By ZetaStax in forum Video ConversionReplies: 5Last Post: 6th Sep 2019, 19:04
