I am trying to encode a file with this command line
ffmpeg -i "source.mp4" -c:v libx265 -preset slow -crf 23.8 -vf scale=1920:-1:flags=lanczos -x265-params ref=6:bframes=5:no-sao=1:no-strong-intra-smoothing=1:cutree=0:aq-mode=3:deblock=-1,-1:rskip=0:rc-lookahead=80:subme=1:numa-pools=16:frame-threads=4 -c:a copy -movflags faststart output.mp4
Some files are coming back with very different encoding setting. Even the CRF is wrong in mediainfo. I am seeing a warning when this happens that says
[mp4 @ 00000148a5247040] track 1: codec frame size is not set
I googled this and no one seems to mention this warning as causing a problem
I am using a fairly recent build: ffmpeg version 2021-10-03-git-2761a7403b-full_build-www.gyan.dev Copyright (c) 2000-2021 the FFmpeg developers
built with gcc 10.3.0 (Rev5, Built by MSYS2 project)
SOURCE MEDIAINFO:
Video
Format : AVC
Format profile : High@L5.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : avc1
Duration : 32 min 43 s
Bit rate : 20.5 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.099
Stream size : 4.69 GiB (100%)
Writing library : x264 core 157 r2969 d4099dd
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=50 / keyint_min=5 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=25.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Codec configuration box : avcC
X265 OUTPUT MEDIAINFO:
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4@Main
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 5 186 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.100
Stream size : 1.19 GiB (100%)
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=50 / keyint_min=5 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=25.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Color range : Limited
Codec configuration box : hvcC
These encoding settings seem to match the source instead of my encoder settings. Some files encode fine with the exact same settings, but don't have the warning message "codec frame size is not set". I have changed settings around quite a few times and same result for the problem files. If it only happened once I would think a problem with the source but it has happened to 2 of the last 4 files I encoded, so I must be missing something. It might just be incorrect metadata in the output, but I don't know for sure. Please help
Edit: This is not happening in Handbrake
Even encoding
ffmpeg -i "input.mp4" -c:v libx265 -preset veryfast -crf 23.8 -c:a copy output.mp4
Is giving the wrong encode setting in MediaInfo
Edit: Tried different build, same problem
Please helpLast edited by tony95; 9th Dec 2021 at 15:05.
Apparently this is a bug in the August 2021 build, I am rolling back to the July build, seems to resolve the issue.
FFmpeg - remove encoding settings from output
By osmium in forum Video ConversionReplies: 3Last Post: 15th May 2021, 06:08 -
FFMPEG X265 Parameter help please
By iKron in forum Video ConversionReplies: 6Last Post: 9th May 2021, 20:42 -
Is my x265 settings are correct?
By megapro17 in forum Video ConversionReplies: 2Last Post: 12th Apr 2020, 08:48 -
Help with x265 settings
By ACKR in forum Video ConversionReplies: 0Last Post: 1st Apr 2020, 21:03 -
Which codec and settings for still image videos when encoding with FFmpeg?
By konstantinusz in forum Video ConversionReplies: 4Last Post: 12th Dec 2016, 10:06
