Dears,
could you please recommend me a tool (windows / macOS) which can easily and quickly extract audio form TS video format (file). I really want to avoid re-encoding or losing quality. Audio is already in low quality.
Thank you very much for your tips
Kind Regards,
VLP
Code:Format : MPEG-TS File size : 1.50 GiB Duration : 1 h 49 min Overall bit rate mode : Variable Overall bit rate : 1 948 kb/s Video ID : 2875 (0xB3B) Menu ID : 5155 (0x1423) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : 27 Duration : 1 h 49 min Bit rate : 1 593 kb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Scan type, store method : Interleaved fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.154 Stream size : 1.22 GiB (82%) Audio #1 ID : 2885 (0xB45) Menu ID : 5155 (0x1423) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Format settings : Joint stereo Codec ID : 3 Duration : 1 h 49 min Bit rate mode : Constant Bit rate : 128 kb/s Channel(s) : 2 channels Sampling rate : 48.0 kHz Frame rate : 41.667 FPS (1152 SPF) Compression mode : Lossy Delay relative to video : -1 s 130 ms Stream size : 101 MiB (7%) Language : Czech
Unable to extract audio data to wave file on Subtitle edit 3.5.16
By Nakasofi in forum SubtitleReplies: 1Last Post: 14th Sep 2020, 04:42 -
Extract avidemux encoding settings from existing video file
By cristian3095 in forum Video ConversionReplies: 0Last Post: 3rd Oct 2019, 10:49 -
How to extract audio track of .avi file to include it in a .mkv file?
By nickiman in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2019, 06:15 -
how to extract lossless audio from an MKV file - ffmpeg fails
By batemanj in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2019, 07:50 -
Convert .mov file to .mp4 (without losing quality) for playback on a 42" TV
By cjborntorun in forum Video ConversionReplies: 3Last Post: 9th Feb 2017, 06:45
