I found an ould VHS tape with family moments and wanted to get it converted so I can play it on my PC. I have an old Panasonic DMR-ES35V video recorder that can directly copy the VHS tape to DVD. After recording the DVD plays fine on the TV, but the problem is that when I insert it in my computer (troed on both Windows and Apple) but it does not recognize the media. It tells me that no media is inserted. Has anyone any good suggestions regarding this?
Thanks for any ideas.
Inger
Results 1 to 18 of 18
1. Did you 'finalise' the disk ?
2. There are two modes of recording. a) Video Recording mode and b) Video Mode. Only b) is guaranteed to work in a PC -
Re 1. Tried both. None of them worked. Couldn’t see the disk on the pc either way.
Re 2. I had no idea. Do you know how I can check what this setting is set to? -
Thank for a great piece of advice. Found the setting. Works like a charm 👍😊
Good to know.
I was going to point you to the user manual which would have covered the issue. -
Well one step further in the process, I have now recorded a DVD and successfully played it from the Panasonic DVD player. When inserting it into my Windows PC it will play fine some of the way, but then it gets delayed and stops at intervals. I have tried copying the contents just as directories, which proves unsuccessful and I have tried creating an iso image which is equally unsuccessful. Both seem to take forever and the iso utility tells me that there are many bad sectors on the disk. The disk is recorded as a SP format. Any suggestions on what I might try?
Likely the quality of your burnable media. What brand are you using ?
Try to source some Verbatim Azo 16x. Your manual will also guide you as to what speed of disks will optimally work. -
Sony DVD +R Ver 1.3/1x-16x 120 min/4,7GB
Not my expertise at all, but I have used them quite a lot with no problems. Just a bit old - does that matter? -
Sony do not actually make the disks that show their name. And the actual manuf. will change over the years.
Of course it could also be that the laser on your PC dvd drive is dying which can cause read issues. -
Could be. It’s almost at the same time on the DVD the problem starts. Tried different VHS tapes and a few different DVD’s now. Still the same. Considering a converter cable to connect video out to USB on my pc
If the issue occurs near the end of the disc it's probably bad discs your burning with,are all the dvds you tried the same brand?
Unfortunately it’s only the first 5-6 min that are playing fine. Then the problems start and get continually worse with time played. Starting to wonder if my PC’s DVD player is bad. The DVD plays perfectly on the videoplayer.
Sounds like your pc player.Can you try the disc on another disc drive?
I did. Problem is that it’s just as old as the other one, so I’m uncertain what it proves.
But if it plays in the other one it kinda proves that the player is the issue now. Different drives will have different life-spans due to useage and other factors.
Oh, sorry. I forgot the very important point that it played just as terrible in the second one, which is an old macbook pro. That’s why I’m uncertain what it proves.
Well I would try other media now. Do try to get the Verbatim I mentioned earlier. And do try -R disks not +R just in case these old players have issues (it has been known) with +R media. There is a lot of cheap media out there some with well known names on them.
But I do guess that you played the disk all the way through on the machine you created it on.
Panasonic DVD recorder passthrough settings (DMR-ES10, DMR-ES15, DMR-ES25)
By Brad in forum Capturing and VCRReplies: 462Last Post: 21st Aug 2025, 06:33 -
Panasonic DMR-ES15 DVD Recorder Remote Control Programming
By czarship in forum DVD & Blu-ray RecordersReplies: 11Last Post: 14th Jul 2020, 19:12 -
Panasonic DMR-ES15 DVD Drive Intermittently Works
By alitek12 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Jun 2020, 00:15 -
Panasonic DMR ES35V DVD NoRead repair
By Lumpy2 in forum DVD & Blu-ray RecordersReplies: 32Last Post: 9th Jul 2018, 21:15 -
Is it possible direct recording on dvd r with Panasonic dmr ex768
By nusratjaveid in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Aug 2017, 12:40
