So I've been using Subtitle Edit for the last 1 or 2 months lately, I use its video panel to edit my subs, and because my screen is very small both their panels are very small when i have waveform on show but if I disable waveform the video panel goes on the bottom half on the screen which makes it very difficult to work with, so I was wondering if there's a way to have the video panel on the right/left without having the waveform enabled.
TL;DR: Is there a way to change these panels locations?
[Attachment 62208 - Click to enlarge]
[Attachment 62209 - Click to enlarge]
In menubar, go to Video --> Undock Video controls
Preview window will detach and go float; you can change size and drag it anywhere.
Subtitle Edit - waveform problem
By AllaRosie in forum SubtitleReplies: 8Last Post: 12th May 2024, 06:21 -
Subtitle Edit not showing subs in video and waveform
By evayor in forum SubtitleReplies: 3Last Post: 5th Jun 2020, 02:31 -
Subtitle Edit waveform centered
By spiffhero in forum SubtitleReplies: 3Last Post: 15th Jun 2019, 13:07 -
Subtitle Edit - Waveform not complete
By batko in forum SubtitleReplies: 0Last Post: 29th May 2019, 10:51 -
waveform problem in Subtitle Edit 3.4.6
By whitelighter27 in forum SubtitleReplies: 2Last Post: 15th Mar 2019, 07:14
