I am trying to import a mkv in multiavchd ad an menu to it and then burn it on a blu ray disc.
When i import the file it says video: unsupported at the Properties tab.
Does anyone how to fix this?
Results 1 to 13 of 13
I forgot to place multiavchd in the title and don't know how to change it.
Can anyone explain or do that for me? -
Format : Matroska
Format version : Version 4
File size : 41.6 GiB
Duration : 2 h 11 min
Overall bit rate : 45.2 Mb/s
Encoded date : UTC 2021-02-12 01:51:56
Writing application : mkvmerge v53.0.0 ('Fool's Gold') 64-bit
Writing library : libebml v1.4.1 + libmatroska v1.6.2
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 43.6 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.219
Stream size : 40.1 GiB (96%)
Title : ROTJ OTD83 v1.2 re-encode
Writing library : x265 3.4+30-23583c4cb:[Mac OS X][clang 10.0.1][64 bit] 10bit
Encoding settings : cpuid=1049583 / frame-threads=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=240 / gop-lookahead=0 / bframes=8 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=40 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=15.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / min-vbv-fullness=50.0 / max-vbv-fullness=80.0 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=1 / transfer=1 / colormatrix=1 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pass
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Format settings : Dolby Surround
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 384 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 362 MiB (1%)
Title : 1983 35mm Optical Audio (from 4K83)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Stream size : 603 MiB (1%)
Title : 5.1 surround mix 2018 version (from 4K83)
Language : English
Default : No
Forced : No
Audio #3
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 kb/s
Channel(s) : 1 channel
Channel layout : C
Stream size : 181 MiB (0%)
Title : 1983 mono mix 2018 version (from 4K83)
Language : English
Default : No
Forced : No
Audio #4
Format : AC-3
Codec ID : A_AC3
Bit rate : 384 kb/s
Title : 1993 stereo remix (LaserDisc PILF 175703)
Language : English
Default : No
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 2 h 0 min
Bit rate : 37 b/s
Count of elements : 949
Stream size : 33.5 KiB (0%)
Title : English Subtitles
Language : English
Default : No
Forced : No -
AFAIK AVCHD only supports HD up to 1920 pixels. Not 4K.
Also AVC (h264) and not HEVC (h265)
You would have to re-encode and resize to use that program. Or create a UHD disk in a bluray authoring program. -
Ah ok thanks
Do you know a good free to use program for 4k files?
Or a program to rencode to 1080p? -
You can try avidemux. That can certainly resize and re-encode for you.
Full spec for AVCHD is here
https://www.videohelp.com/hd -
Since i couldn't delete my replay his thread because his last thread was locked due to a wizard download. So I'm removing what i said as a replay.
ffprobe : Unsupported codec with id 0 for input stream 0
By jean202 in forum Capturing and VCRReplies: 2Last Post: 28th Jul 2021, 07:32 -
Can't download stream - new but not unsupported website
By kikohbc in forum Video Streaming DownloadingReplies: 27Last Post: 18th Apr 2021, 13:24 -
How to copy unsupported data streams with ffmpeg?
By mckfabio in forum Video ConversionReplies: 2Last Post: 12th Jul 2020, 10:44 -
Recover_mp4 Error: Unsupported video format
By DChosid in forum Video ConversionReplies: 9Last Post: 15th Jun 2018, 11:34 -
Some of my video files are unsupported - PLEASE ASSIST ME
By jarod1005 in forum Newbie / General discussionsReplies: 20Last Post: 17th Jul 2017, 10:11
