Hi
As mentioned, my projects is mostly made of still pictures, at least staying still for a 4 or 5 seconds if not more, and transitions are quick.
I could see how ffv1 and utvideo don't cut it at all, even with big GOP numbers... the sum total of all project files, pictures and soundtracks, amounts to 2,6 Go. Invariably the resulting lossless file is more than 10 Go. The resolution is fullHD (1920 x 1080), 25 frames per second. But it SHOULD have interframe prediction: mostly still pictures, dammit.
If someone has a clue...
Thanks, Mehdi
Possibly lagarith with the "null frames" option enabled. It can essentially encodes 1 frame for each still frame.
But it depends on how your "project" is going to be used. Not all programs and players are compatible with lagarith null frames
The other option is specifying VFR timecodes (so each still frame is only 1 frame). But not all programs compatible with VFR - most players should be
The sum total of all project files, pictures and soundtracks, amounts to 2,6 Go. Invariably the resulting lossless file is more than 10 Go.
Lossess compression is with respect to the uncompressed (decoded) state . It would probably be ~ 20 Gb uncompressed -
still frames or not h264 managed well, and the file is the same size as the sum of all pictures+soundtracks. Interframe compression...
the footages are only a few limited in the whole project, and uncompressed.
I didn't know h265 (HEVC, right ?) had a loss mode.
I'm interested in testing lagarith, but on linux ? Doesn't seem to exist. -
h265(hevc) using x265 has a lossless mode, but it's generally produces worse compression than x264
lagarith encoding is windows only, but libavcodec/ffmpeg can decode it
If you have transitions, the benefit becomes diminished
In a sample video test with images (e.g. slide show), RGB, no transitions - libx264rgb was ~ 20% larger than lagarith using null frames. But adding short 1sec cross dissolve transitions, lagarith was now ~ 5% larger than libx264rgb
The more still images or static content - the more lagarith null frames benefits; but the more different frames, it has to encode intra frame (lagarith does not use long GOP)
Does anyone here know how to use these lossless codecs?
By Guernsey in forum Newbie / General discussionsReplies: 16Last Post: 25th Jul 2021, 17:17 -
Quick sanity check: Lossless to lossless encoding HuffYUV to UTVideo
By nicholasserra in forum Video ConversionReplies: 2Last Post: 20th Aug 2020, 11:41 -
Incorrect video cut timing on MKV video with lossless quality
By may5224 in forum EditingReplies: 8Last Post: 19th Nov 2019, 15:02 -
FFMPEG - hevc_nvenc & h264_nvenc lossless presets not truly lossless?
By AnomalyDetected in forum Video ConversionReplies: 5Last Post: 27th Oct 2019, 02:24 -
MSU Video Codecs Comparison 2019 - CALL FOR CODECS
By DmitriyK in forum Latest Video NewsReplies: 0Last Post: 19th Feb 2019, 02:25
