This seems backwards. I usually have problems getting my Samsung to play files that are fine on PC.
Samsung - 60 Class (60 Diag.) - LED - 2160p - Smart - 4K Ultra HD TV
Model: UN60KU6300FXZA Updated firmware major version: 1250
.TS files made with Hauppauge 1512
Edited with Videoredo V6
I have been testing and testing some edited .TS recordings. I've done quick stream fixes saved to mp4 which would have stutter/flicker on the TV but not on PC.
Then tried the MKV container and viola! Perfect on the TV but all kinds of pixelization playback on desktop Windows 10
Very strange. I still have the master files which play fine unedited with the project file with cut points if needed.
What player are you using to view on your pc?
Yes. Thanks if you can see if there's any thing wrong causing this problem.
General
Unique ID : *
Complete name : C:\Users\*\Documents\*\*5.1 audio master edit.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 8.39 GiB
Duration : 2h 8mn
Overall bit rate : 9 383 Kbps
Writing application : VideoReDo (Lavf58.29.100)
Writing library : VideoReDo (Lavf58.29.100)
Video
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 8mn
Bit rate : 8 979 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.144
Stream size : 7.88 GiB (94%)
Writing library : x264 core 160 r3000
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=4 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=8 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=tff / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=54 / keyint_min=5 / scenecut=0 / intra_refresh=0 / rc_lookahead=20 / rc=abr / mbtree=1 / bitrate=8979 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=24999 / vbv_bufsize=4688 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Default : No
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
DURATION : 02:08:02.274000000
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 2h 8mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 352 MiB (4%)
Language : English
Default : Yes
Forced : No
DURATION : 02:08:02.312000000
Menu
00:00:00.000 : :Chapter 1
00:02:55.708 : :Chapter 2
00:08:12.091 : :Chapter 3
00:10:22.688 : :Chapter 4
00:15:14.280 : :Chapter 5
00:22:03.288 : :Chapter 6
00:29:12.283 : :Chapter 7
00:36:58.616 : :Chapter 8
00:43:04.181 : :Chapter 9
00:45:30.294 : :Chapter 10
00:48:36.380 : :Chapter 11
00:52:47.898 : :Chapter 12
00:57:11.661 : :Chapter 13
00:57:35.685 : :Chapter 14
01:02:24.340 : :Chapter 15
01:08:18.894 : :Chapter 16
01:12:27.676 : :Chapter 17
01:15:55.050 : :Chapter 18
01:19:08.176 : :Chapter 19
01:25:21.716 : :Chapter 20
01:30:26.387 : :Chapter 21
01:32:09.891 : :Chapter 22
01:38:57.731 : :Chapter 23
01:47:22.636 : :Chapter 24
01:55:02.495 : :Chapter 25
01:59:44.744 : :Chapter 26
Create .ts files from a .mkv file while still recording the .mkv
By RKJ in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2020, 22:51 -
Multiple MKV files required to be in same folder to play properly
By AgKwo in forum Video ConversionReplies: 4Last Post: 8th May 2020, 07:34 -
How to play MKV files on Samsung Home Theater DVD Player?
By askfriends in forum Newbie / General discussionsReplies: 7Last Post: 25th Apr 2019, 04:13 -
Merging MKV extracted files to playable MKV video file
By deepfrayder in forum EditingReplies: 9Last Post: 13th Dec 2017, 00:17 -
PowerDVD does not play certain mkv files in 3D
By maeries in forum Software PlayingReplies: 4Last Post: 7th Sep 2017, 05:59
