Hi. If anybody wanted to see a video about different DeInterlacer's (In this case Yadif & QTGMC) for the 1000'th time, then i have made a YouTube video showing the filters off
I have upscaled the video to 4K so you can see all the detail in the clips.
https://www.youtube.com/watch?v=NCd4_VS6WvQ
Thanks.
I swear by QTGMC but that right-side example has extreme ghosting (if that's the correct term). Look at the right side of the fellow's head, especially his right ear and collar.
It is hard to compare when there is a lot of compression artifacts and line timing errors, a.k.a wiggle. Line wiggle is more apparent in the QTGMC sample and has less details due some denoising action.
@ Barrythecrab it's an artifact of analog transmission and/or recording. It's there in all three versions of the video but the QTGMC version makes it stand out the most.
@Skiller The original VHS capture had large ammounts of ghosting. the QTGMC setting was on placebo. Is the “Slower” function better?
I believe the slower the setting the more denoising you get, Try the fastest option so you can avoid denoising. I found QTGMC works better with a VCR built in TBC/DNR and gives rock solid clean video, If noise and line timing are present QTGMC turn those into what I like to call "boiling effect" where noise pixels are agitated left and right throughout the frame. If no hardware DNR is available try denoising first with another app and then procede to QTGMC with the fastest setting.
I like how the "original interlaced" is deinterlaced. Youtube will never give you accurate samples of deinterlacers, too compressed, Youtube does whatever it wants to your video. The mere act of (trying to) upscale to 4K will itself mess with quality.
Yadif leaves jaggies.
QTGMC can have NR depending on settings.
Nothing new here.
@AntonHarboe, learn QTGMC settings, use QTGMC, forget about Yadif (predates QTGMC, inferior).
@dellsam34: I've seen that, but only for the 59.94fps. If you drop frame, 29.97fps used, all is well.Want my help? Ask here! (not via PM!)
yadif custom settings
By radusound in forum DVD RippingReplies: 18Last Post: 14th Dec 2020, 09:41 -
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 14Last Post: 12th May 2020, 10:53 -
[avisynth] is there an alternative to YADIF?!?
By marcorocchini in forum Newbie / General discussionsReplies: 37Last Post: 15th Jan 2020, 18:19 -
Deinterlacing with VirtualDub's Yadif filter?
By dellsam34 in forum CapturingReplies: 44Last Post: 29th Jul 2019, 14:27 -
How to use Yadif to remove this one bad frame?
By digicube in forum RestorationReplies: 2Last Post: 18th Jun 2018, 21:47
