when i run avs2dvd it crashes when its processing the 2 files in the attached image, the attached image has some info about them
any ideas? any way to fix this?
[Attachment 62130 - Click to enlarge]
Have a look at the log for any further info. Program creates it in the output folder
It failed procesing the audio, the video seemed compete, it created a 2.6GB temp m2v file
Install LAV filters.
https://www.videohelp.com/software/LAV-Filters
Right click the A2D icon and select "run as adminstrator"
At the top select Codecs/Preferred directshow codecs setup
For H.264/AVC (video) and AAC (audio) select the LAV filters button
Close the window, close A2D and open normally.
Retry your project
Avs2dvd
By MHHMHH in forum SubtitleReplies: 4Last Post: 27th Nov 2021, 15:01 -
AVS2DVD ffmpeg encoding incorrect SAR.
By SF01 in forum Authoring (DVD)Replies: 95Last Post: 28th Aug 2020, 14:35 -
AVS2DVD error audio duration shorter than expected
By SF01 in forum Authoring (DVD)Replies: 18Last Post: 21st Mar 2020, 03:49 -
Using Zones with HCEnc
By koberulz in forum Newbie / General discussionsReplies: 15Last Post: 17th Jul 2019, 02:24 -
AVS2DVD generating bigger ISO than DVD. Can't burn.
By SF01 in forum Authoring (DVD)Replies: 7Last Post: 15th Feb 2019, 07:34
