I mean an ATSC receiver dongle that actually sends the demodulated MPEG-TS to the PC, and lets the packaged software decode the video from the TS, NOT the more typical kind that does MPEG-TS processing in the dongle and then just sends MPEG audio and video streams to the PC. The more typical kind loses a lot of the metadata stored in the TS, and when you have the software save a video file it's just a .mpg file with the video and audio streams stored. The kind of ATSC receiver dongle I'm looking for would actually allow you to save the transport stream itself to a .ts file (which can be played back in VLC player or FFPLAY, or actually have its metadata extracted with various software including MPEG-TS analysis software or FFPROBE).
It is likely that any ATSC PC tuner for Windows could work but you will probably need to use Graph Studio and build a filter graph to get what you want. Here is an example https://forum.videohelp.com/threads/366694-How-to-capture-video-chunks-frames-of-data-...50#post2342251
The HVR 2250 is a PCI-e card, which I don't have installed anymore.Ignore list: hello_hello, tried, TechLord, Snoopy329
How to play the recording of a Sony Bravia TV on a usb stick?
By cypherinfo in forum Video ConversionReplies: 12Last Post: 11th Jan 2021, 17:49 -
How good is this ATSC modulator?
By Videogamer555 in forum DVB / IPTVReplies: 9Last Post: 20th Mar 2020, 12:16 -
Newbie help VHS tape conversion using dv camcorder or newer usb dongle ?
By Nickv48 in forum Capturing and VCRReplies: 2Last Post: 15th Feb 2020, 01:47 -
USB TV Tuner for all Regions (ATSC, DTMB, DVB-T/DVB-T2, and ISDB-T)
By SuperLOL in forum DVB / IPTVReplies: 8Last Post: 6th Jan 2020, 21:42 -
Cheap USB Dongle / Hi8 to Mac / Badly distorted any point in trying to fix?
By mahu1982 in forum RestorationReplies: 2Last Post: 31st Oct 2019, 20:43
