mpd url
lic urlCode:https://drvideo-ak.akamaized.net/video-sg2/5e204b0b-9458-4595-87c1-cdc6fab9682e/5426.ism/manifest(format=mpd-time-csf)
auth bearer token request maybeCode:https://drvideo.keydelivery.mediaservices.windows.net/Widevine/?kid=45d657e0-0591-4f6d-b51c-d27bc1f839fc
Dr-Platform: androidCode:https://api-a0.marrow.com/v3.1/gtoken/android/Z1lySGlYUnJDaHRjVlBVd2MvaGFIbVp1U2xhdGhkN3VaZCtjQzZQYzYva3pGT1NJVUlIcFRuUVljSHNoME9aYk1pTDVnczhST2tHcWxBK1IyZVV6Z1E2cFlPVFNqRHBnMmkxVStEVkVRcENEdHVYbytlNFFQeUtZNnZhMWxieDl6QUdDZjhTclMrOXREdFRvZXlqaEozQzh4WkNmYzM4SmtEOHg1eGhGSTI3L2dFTkpxZ3Y0dC9CWUE0SXJPNnFvb3pCRjd5MjFXemZPVXJMcUlxa2J2NVkwS2d0bjFpZS93ak9KdncxWVFLTWs0RDQ3Unh1NUpSZ2NWWmNWNUNkRXRrd0c3eFhjSThyWDlXU1RxT2t4MDRLYjJubjhsZFUzT00xMUNKUWYwR0VINmdrOUx5cEV5ckQyU3F6Y0o4cWNRVUI4Wkwzbms2elBwM2ozQVVwWlhnTT0=
Dr-Dv: m.2061a6e23daeed98
course-id: 1
Dr-UID: 6197bdf7aa8ded1766241523 - MFREE
Dr-App: marrow
Dr-Dv-ENC: vkbVA6Q1KUTw3H5YES84ArP6g6jlu9XbtxuKk4LDBocz0z4x/DiQmxFryIdp+OZ2Kg==
Dr-Dv-Model: M2007J17I
Dr-Token: .eJxVztEKwjAMheF3ybXI2m7p5suUaDIouKVksl2I725HQfD25-Nw3pAyww3QTfHOcyQaWdhFRN-7wQe4AFti2fNDKluuvkNHKD4wifA0NkClpF1sy7pWFbqhZd3-6s-eS2SmRyvlSa9ZbamZVjatjz5fps8vnA.FHlPdw.cU9iv7UGWbB z-O5eqWVeewLMDSY
Dr-App-Version: 308
Dr-Dv-Ts: 1638389113706
Content-Type: application/octet-stream
User-Agent: Marrow/7.15.1 (com.marrow; build:308; Android 11(30); Device)
Accept-Encoding: gzip
Content-Length: 2114
Host: api-a0.marrow.com
Connection: Keep-Alive
Stop reposting no one helped you before because the data you provided was not enough Headers are very strict and time limited.
Code:{"code":1201,"error_msg":"Your phone date & time is inaccurate! Adjust your clock and try again. EP 01","status":"failed"}
With my time I get this error
Code:{"code":400,"error_msg":"Invalid value for Dr-Dv-Enc, DVENC 04","status":"failed"}Last edited by notaghost; 3rd Dec 2021 at 14:55.
discord=notaghost9997 -
@notaghost I get "keys":"Error:RSA key format is not supported" using your web to get keys, any help?
No are you serious, notaghost will not be able to help you without more details about webs
RSA key format is not supported means the license url response is not what it should be. If license url gives you an error it is not license response you will get RSA key format is not supported
Widevine CDM
By KyoGo in forum Video Streaming DownloadingReplies: 8Last Post: 19th Jul 2023, 04:43 -
Widevine help
By Stevo1987 in forum Video Streaming DownloadingReplies: 16Last Post: 27th Aug 2022, 13:08 -
widevine decrypt help
By birbal1 in forum Video Streaming DownloadingReplies: 12Last Post: 23rd Nov 2021, 14:47 -
Found an awesome script to download widevine content (mpd) and decrypt it
By royjeon215 in forum Latest Video NewsReplies: 8Last Post: 11th Nov 2021, 16:26 -
widevine decrypt extension for microsoft edge not working
By takheang303 in forum Video Streaming DownloadingReplies: 6Last Post: 3rd Apr 2021, 12:46
