I have a DVD box set with one faulty disk. I managed to copy this to the hard drive using AnyDVD intending to burn it to a DVD-R.
However is is dual layer which my burner isn't.
So I tried to use Handbrake to make mkv files on each episode. However HB only shows me 2 files:
Title: 1 (00:00:47)
Source: C:\Users\Desktop\CF\dvd\VIDEO_TS
Title: 6 (00:02:11)
Is there any way to make HB to do all episodes? Thanks.
Results 1 to 13 of 13
No I can't play it from the HDD, only the first 2 short items which are trailers for other things and thought VLC was not showing a Top Menu.
I'm now thinking my rip is faulty even though no errors were reported. Nero tells me (when making an image) that several .BUP files
are not identical.
@Skiller thanks for telling me I never knew that. And have never seen a DL blank. Shows what i know! -
The plot continues, I changed to a brand new optical drive and it seems to read the disk ok now. But results are identical. I can only play the first 2 trailers in VLC or see them in HB. After playing them it does nothing. If I rip the disk with AnyDVD there's 20 files, of which only 2 are more than 14KB. The 2 trailers?
But if I look at it in Explorer I see 33 files, 5 of which are over 1GB. They must be the files I want. Is there any way I can access them ? -
This has been quite a revelation. Yes the disk plays on Panasonic DVDR. After the 2 trailers a menu appears and everything (so far) lloks ok.
I installed make mkv which outputted:
MakeMKV v1.16.5 win(x64-release) started
Using direct disc access mode
Title #1 was added (5 cell(s), 0:25:58)
Title #2 was added (8 cell(s), 0:36:21)
Title #3 was added (10 cell(s), 0:49:42)
Title #4 was added (10 cell(s), 0:50:23)
Title #5 has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 1-1 were removed from title start
Cells 3-3 were removed from title end
Title #6 was added (1 cell(s), 0:02:10)
Title #7 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Title #17/0/1 has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17/0/2 has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 2-end were skipped due to cell commands (structure protection?)
Title #19/0/1 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19/0/2 was added (1 cell(s), 0:02:10)
Title #19/0/3 has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 was added (1 cell(s), 0:02:36)
Title #21 has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 was added (1 cell(s), 0:02:36)
Title #24 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 4 in VTS 5 is equal to title 1 and was skipped
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'DVD+R-DL PLEXTOR PX-891SAF 1.JI 3743524772 2F8851500600' at offset '0'
(The above line was repeated 30 times) then
The source file 'DVD+R-DL PLEXTOR PX-891SAF 1.JI 3743524772 2F8851500600' is corrupt or invalid at offset 30720, attempting to work around
Encountered 36 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
Operation successfully completed
I could then see about 6 titles all ticked and clicked the Save icon.
Currently working and progress about 20% -
Time remaining is increasing and many more errors being reported. This is near-new disk (no scratches etc) and new DVD .
The files copied to HDD without reporting errors. Any thoughts on that?
Can I use those files with MakeMKV instead of the optical disk?
Are these actual problems or intentional bugs to make copying harder? -
Not the one I have... no choice, optical or nothing. I do suspect there's something wrongwith the disk as in manufacture. It's also 2007 so no new wizardry.
But something must let it move after the 2 trailers to the main menu. Would have tried PowerDVD but a bit pricey.
Am I mirroring or duplicating the pc monitor screen
By jraju in forum Newbie / General discussionsReplies: 7Last Post: 19th Mar 2021, 22:55 -
Making MKV from multiple BRD playlists without duplicating m2ts files
By TkerThor in forum Blu-ray RippingReplies: 0Last Post: 27th May 2020, 23:59 -
Make a 'hot key' for 'Duplicating' lines in Aegisub
By Kinderzoo in forum SubtitleReplies: 2Last Post: 14th May 2019, 05:19 -
de-duplicating / decimating ProRes losslessly?
By chconnor in forum Video ConversionReplies: 17Last Post: 20th Apr 2017, 21:44 -
Duplicating Home Movies
By dtroitlions21 in forum MacReplies: 13Last Post: 14th Dec 2016, 05:42
