Hi all,
Which Linux OS is more suitable to run;
Kdenlive - the alternative to AviSynth
Kdenlive
https://kdenlive.org/en/
Debian ?
Ubuntu ?
Linux Mint ?
Please advise. Thanks
Furthermore any folk has run AviSynth on Linux OS ? Does it work ? Does it need to run on wine ?
Regards
Results 1 to 12 of 12
It should work on any distro but I think the 'K' might hint it is best with the K Desktop Environment (KDE). I can confirm it works well on Kubuntu.
I have no idea about AviSynth but there is a good chance it works in Wine or Crossover. You may not need it though, Linux video apps are plentiful and there is probably a native alternative available.
Brian. -
I agree with what betwixt says about Kdenlive and have used it on quite a few distros over the years. It used to be that it would only work properly on KDE desktop, but that doesn't seem to be the case any more.
Vapoursynth appears to be a replacement for Avisynth, although I have never used either. It depends on which distro you pick as to what is in the repo. For example in the two distros I am running both are in the Manjaro repositories, although only Vapoursynth is available for MXLinux as a Flatpak, which suggests it can be used on any distro that will run Flatpaks. -
Hi Brian,
Thanks for your advice.
Can it works on Gnome desktop? I'm running Oracle VirtualBox here. I can create an Ubuntu 20.04 VM running KDE desktop for testing. Most times I run Gnome desktop.
As far as I know there is an AviSynth+ version for Linux. I'm running both Windows and Linux here. I have been trying to install VirtualDub and VirtualDub2 on Windows 10 without success. It took me spending 4 days working on it without a solution therefore I'm considering coming back to Linux in video editing.I have no idea about AviSynth but there is a good chance it works in Wine or Crossover. You may not need it though, Linux video apps are plentiful and there is probably a native alternative available.
Kdenlive is on Ubuntu 20.04 repo. Where can I find documents re writing scripts for Kdenlive? Thanks
Regards -
Hi DeJay,
Thanks for your advice. I have no problem running KDE desktop.
I have been running Red Hat, Ubuntu, Debian, Linux Mint, Gentoo, Fedora etc. in the past but never ran Flatpak before.Vapoursynth appears to be a replacement for Avisynth, although I have never used either. It depends on which distro you pick as to what is in the repo. For example in the two distros I am running both are in the Manjaro repositories, although only Vapoursynth is available for MXLinux as a Flatpak, which suggests it can be used on any distro that will run Flatpaks.
Just found;
What is Flatpak?
https://itsfoss.com/what-is-flatpak/
I'll try it, just creating a Flatpak VM on Orcale VirtualBox for testing.
Now the most import thing for me is where can I find documents re creating scripts for Vapoursynth ?
Regards -
Hi all,
A further question;
Which one shall I select Vapoursynth or Kdenlive ?
I found following links on Internet
Andrew's Tutorial Blog
Tutorial - Using VapourSynth vs AVISynth+ for QTGMC: Round One
http://macilatthefront.blogspot.com/2018/12/using-vapoursynth-for-qtgmc-round-one.html
AviSynth vs AviSynth+ vs VapourSynth: which one should I choose?
https://video.stackexchange.com/questions/28548/avisynth-vs-avisynth-vs-vapoursynth-wh...hould-i-choose
Regards -
I have tried Blender and OpenShot before. They can't help me. The video were taken with a Sony V8 Video camera in about 1990. The video works no problem on cathode-ray tube TV. But the video is not clear on today's display. I have increased the resolution from 720 to 1920 but the result was not good. The size of the video increased 5 times.
I'll try Kdenline on Ubuntu 20.04, gnome desktop first. If it doesn't work good I'll change it to KDE desktop. -
for the CRT view, were you playing the original analog tape? how was the original analog tape digitized?
lots of old TV shows are being digitized not from the videotapes but from the original film copies. and there's a reason or two for that.
KdenLive is not rendering and crashes every time I try to render.
By FireFlash in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2020, 23:01 -
Using Shotcut features in Kdenlive
By DeJay in forum LinuxReplies: 2Last Post: 20th Jul 2019, 12:22 -
Kdenlive still unstable
By DeJay in forum LinuxReplies: 19Last Post: 23rd Feb 2019, 09:01 -
Blank green monitor kdenlive
By David Banner in forum EditingReplies: 0Last Post: 22nd Feb 2019, 07:03 -
Kdenlive glitch
By DeJay in forum LinuxReplies: 11Last Post: 15th Apr 2017, 10:06
