I'm trying to reposition a subtitle so that it doesn't cover up an opening credit. I've moved it to Middle/center and the opening credit can be seen, but now the subtitle is covering an actor's face. Is there a way to move it down just a couple lines? I tried pressing Enter twice to create a couple blank lines but it didn't work.
Thanks, I tried that but it didn't work. I tried both {\pos((320,240)} and {\pos(200,200)} but it stayed the same place on the screen. Does this need tag need to be entered in conjunction with an alignment tag or something? I had the alignment set to bottom/center.
Perhpas you're using a font larger than the resolution of the video allow.
It still wouldn't work with the subtitles I was trying to reposition before, but it worked with ones at a different spot in the .ass file. Maybe those particular subtitles got corrupted somehow and I should just delete them and redo them.
Thanks for your help. -
You can also update subtitle edit to 3.6.4.
Maybe OP is using a player that doesn't support *.ass and/or doesn't honour other positioning tags than the {\an*} ones.
If his player supports PGS, he can export to Blu-ray sup.
Text Alignment Issue (all programs)
By Audiovisual in forum Newbie / General discussionsReplies: 12Last Post: 22nd Sep 2020, 08:55 -
Subtitle Edit time shifting issue
By vid100 in forum SubtitleReplies: 3Last Post: 7th May 2020, 20:20 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 19:52 -
Subtitle Edit OCR import issue
By nunit in forum SubtitleReplies: 3Last Post: 16th Apr 2019, 20:48 -
Strange issue with subtitle edit 3.5.7
By batemanj in forum SubtitleReplies: 1Last Post: 17th Feb 2019, 02:18
