Hello,
Goal: Open RTSP stream in MPC BE by clicking on a file.
I could do this in VLC by creating a text file with rtsp url inside then renaming extension to .rtsp and assigning windows to open the file type with VLC.
When I do the same in MPC BE it does not work. It says cannot render file.
If I enter url directly in open file/url under file menu it works.
Anyone got solution?
Results 1 to 1 of 1
Redirecting RTSP stream
By tzimber in forum Newbie / General discussionsReplies: 2Last Post: 23rd Nov 2021, 15:57 -
FFMPEG Save video from rtsp stream to hls stream
By Wisperrio in forum Video Streaming DownloadingReplies: 2Last Post: 26th Aug 2021, 22:38 -
How can I capture RTSP stream with FFMPEG continously and later decode
By bcalbatros in forum Video Streaming DownloadingReplies: 0Last Post: 17th Apr 2020, 13:01 -
Convert MPTS to RTSP Stream Output
By Dariofil in forum DVB / IPTVReplies: 1Last Post: 25th Jun 2019, 22:08 -
Help needed for PotPlayer using an rtsp-multicast stream
By Bobaloo in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2019, 15:05
