Results 61 to 62 of 62
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Sorry for forgetting to get back to this. I downloaded a 4K AV1 video 60fps video from https://www.youtube.com/watch?v=LXb3EKWsInQ
Tiger Lake's QSV was able to play the video smoothly with continuous audio and tone mapping for HDR when I used the Microsoft Movies and TV app. When I played the same file using VLC, MPC-BE x64, and PotPlayer 64 bit they all successfully applied tone mapping for HDR but either video playback wasn't as smooth, or the audio cut in and out, or both.Code:General Complete name :COSTA RICA IN 4K 60fps HDR _ULTRA HD_.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/av01/iso2/mp41) File size : 915 MiB Duration : 5 min 13 s Overall bit rate : 24.5 Mb/s Writing application : Lavf58.76.100 Video ID : 1 Format : AV1 Format/Info : AOMedia Video 1 Format profile : Main@L5.1 HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : av01 Duration : 5 min 13 s Bit rate : 24.3 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 59.940 (60000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.049 Stream size : 910 MiB (99%) Title : ISO Media file produced by Google Inc. Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : R: x=0.677980 y=0.321980, G: x=0.245000 y=0.703000, B: x=0.137980 y=0.052000, White point: x=0.312680 y=0.328980 Mastering display luminance : min: 0.0000 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1100 cd/m2 Maximum Frame-Average Light Level : 180 cd/m2 Codec configuration box : av1C Audio ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : mp4a-40-2 Duration : 5 min 13 s Bit rate mode : Constant Bit rate : 128 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 44.1 kHz Frame rate : 43.066 FPS (1024 SPF) Compression mode : Lossy Stream size : 4.79 MiB (1%) Title : ISO Media file produced by Google Inc. Default : Yes Alternate group : 1
Is it worth upgrading?
By sophisticles in forum Newbie / General discussionsReplies: 0Last Post: 24th May 2021, 17:24 -
Advice on upgrading my pc
By ricardouk in forum ComputerReplies: 7Last Post: 8th Dec 2020, 19:28 -
Upgrading RAM
By kyrcy in forum ComputerReplies: 6Last Post: 9th Jan 2019, 21:49 -
Upgrading
By kyrcy in forum ComputerReplies: 15Last Post: 23rd Mar 2018, 07:32 -
Upgrading to El Capitan
By Jeikobu in forum MacReplies: 3Last Post: 14th Nov 2017, 11:42
