Howday, I have a 900 MHZ with 356 RAM and am using the Dazzle Digital Video Creator 80 USB hardware with VideoWave 5.0. In the past, on this machine I was able to capture video just fine, but now everything I try and capture is very choppy and slow. It's like the machine cannot keep up with the video transfer rate from my Sony Camcorder. Any one have any ideas? If more info is required please let me know. Thanks!![]()
Assuming nothing has changed on your system, try defraging (Windows Disk Defragmenter) the harddrive where the captured video is saved.
wway -
Ok, I can capture things ok in M-PEG format, but AVI hangs real bad. I can't the clarity of AVI for my VCDs, MPEG is just not cutting it! I have ran defrag three times, plus a complete scan disc with no errors. What else could it be! Damn this Dazzle!
What are you using to play the AVI file. Software such as vdub does not play large AVI's well, as it is not meant as a player, but an editor. Have you tried encoding the AVI to MPEG, is it still choppy.
Craig
Choppy video playback.
By Stealth3si in forum Media Center PC / MediaCentersReplies: 5Last Post: 2nd May 2014, 01:16 -
VirtualDub Capture Mod - Choppy Audio Playback?
By alinhoalisson in forum Capturing and VCRReplies: 11Last Post: 22nd Dec 2011, 12:34 -
Import/Capture Video from MiniDV - Audio is Choppy
By Guy Leatherman in forum Capturing and VCRReplies: 17Last Post: 21st Oct 2010, 11:35 -
VOB2MPG choppy video
By 123fish123 in forum Newbie / General discussionsReplies: 4Last Post: 20th Mar 2009, 12:06 -
Choppy capture from HI8 in Premiere
By tmann in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2007, 14:24
