I have a DVD I'm editing using AVI Synth. The video edits are done, but the final stage is to smooth out audio transitions so that when the video skips over a section of video and audio I removed, the audio transition is gradual instead of abrupt. Is there a recommended way to do this using AVI Synth?
Here are the problems I've had with the methods I've tried:
At first I was using AudioTrim, but the problem I'm having here is that the more edits there are, the more the audio goes out of sync with the video.
So then I decided to use Dissolve with AudioDub to create smooth audio transitions based on the exact frames of the video edits, then export an audio file with smooth transitions created by the dissolves, with the intention of later importing the edited audio file and combining it with the edited video without the dissolves (since the dissolves were only created to gradate audio transitions, and not video transitions). But the problem I'm having here is that every time I use Dissolve, the total frame count shrinks. If this is a viable method for what I'm doing, is there a way to use Dissolve so that it doesn't change the total frame count?
The problem is that Dissolve overlaps the two segments by the specified amount in order to crossfade between them. So you end up with overlap fewer frames. I don't know how complex your AviSynth editing is but you can probably write functions for each type of edit. For example, here's a function that will remove a segment of video with a simple cut transition for the video, but a dissolve for the audio:
Calling it like:Code:function CutWithAudioDissolve(clip v, int start, int end, int overlap) { # simple cut transition for the video v1 = Trim(v, 0, start-1) v2 = Trim(v, end+1, 0) v12 = v1++v2 # cut with dissolve for the audio half = overlap/2 otherhalf = overlap-half a1 = Trim(v, 0, start-1+half) a2 = Trim(v, end+1-otherhalf, 0) a12 = Dissolve(a1, a2, overlap) # join the cut video with the dissolve audio AudioDub(v12, a12) }
will remove frames 50 to 150 (inclusive) with a 30 frame audio dissolve.Code:CutWithAudioDissolve(50, 150, 30)
Remastering SD video in Avi/Vapour Synth
By Reclusive Eagle in forum RestorationReplies: 6Last Post: 17th Oct 2021, 17:12 -
Synth a and b missing after installing ryzen 5600x cpu
By johns0 in forum ComputerReplies: 0Last Post: 23rd Jan 2021, 13:32 -
Help with smooth footage
By dveloper in forum Newbie / General discussionsReplies: 7Last Post: 7th Jan 2020, 13:11 -
Editing transitions
By TBrady in forum Newbie / General discussionsReplies: 0Last Post: 14th Jul 2019, 18:17 -
Installing AVI synth with QTGMC - Please Help :(
By DiggyDre in forum EditingReplies: 21Last Post: 21st Feb 2019, 23:48
