I have VSDC Pro with a Win 7 OS. I can blur faces with a movement map just fine but when I add more than one object (elipse to blur), only the first object will follow the movement map. I can't find a way to make more than one movement map per video. Any suggestions on getting more than one object to follow the movement map? Thanks
	Maybe add another track on the timeline and add your map? It's not important the problem be solved, only that the blame for the mistake is assigned correctly
	Thank You. I ended up splitting the video into four different parts and creating a movement map for each split. I was able to make it work that way. Thanks again for the suggestion.
	Thank you for the reply, now I learned how to do it thanks to you! It's not important the problem be solved, only that the blame for the mistake is assigned correctly
  VSDC - multiple movement animations not working in ExportBy David328 in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2021, 18:55
  [Avisynth+] How to display a luminance mapBy butterw in forum Newbie / General discussionsReplies: 15Last Post: 9th Jan 2021, 08:38
  How to specify/map English only subs in ffmpegBy wallywalters in forum Video ConversionReplies: 4Last Post: 9th Oct 2018, 13:04
  Add map view to video.By Virto555 in forum EditingReplies: 3Last Post: 5th Sep 2018, 18:23
  I need help on creating a video based on route mapBy vbas28 in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2018, 11:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
