So just as a FYI, I have an older JVC VHS C camcorder and I thought why not see if I my EZCap USB would work and digitize the footage. Low and behold, it works! YUY2 in VSDC Free video capture as well as Virtualdub2 worked perfectly! I found the drivers on the EZCap website, keep in mind, this is a real EZcap not one of the cheap chinese knock offs.
Results 1 to 1 of 1
It's not important the problem be solved, only that the blame for the mistake is assigned correctly
Ezcap 280hb VHS issue
By John329385t98 in forum Capturing and VCRReplies: 22Last Post: 10th Nov 2019, 19:53 -
Ezcap 1080p HD Video Capture Device not saving to 1Tb Wd easy store hd
By cybernaut in forum Capturing and VCRReplies: 9Last Post: 30th Aug 2019, 16:30 -
Is Ezcap.tv still trading?
By Gameshow Host in forum Capturing and VCRReplies: 37Last Post: 24th Mar 2019, 08:08 -
I need hdmi cables for ezcap 284
By DreiK in forum Capturing and VCRReplies: 0Last Post: 14th Nov 2018, 14:17 -
EZCAP 280 not working
By cgarratt in forum Capturing and VCRReplies: 1Last Post: 16th Jan 2018, 12:04
