    May 2006
    Canada
    Hello all. Sorry to ask you this, but can any of you can recommand me a good HD capture card in order to use my Sony broacast camera (PMW-EX1r) for zoom streaming on my computer ? I can't find a program compatible with the camera, so the PC can't detect it at all.
    Thanks if anyone can help
    canada
    Please do not cross post the same thread,i deleted your other thread.
  3. Member Cornucopia's Avatar
    It outputs HDMI, so assuming it is "clean" hdmi, there are lots of options. Blackmagic, Aja, Elgato, GV, Magewell, and plenty others.
    I have been using the magewell hdmi-->usb3 capture/adapter box on almost 100 hdmi cameras at my campus, basically running 24/7 for the last 4 years, with hardly an issue to speak of (overheating due to bad placement/ventilation, and v1.00 firmware being those handful of exceptions). clean 1080p60 can't be beat (unless you can afford to upgrade to 4k).
    Works fine as a "webcam" source for Zoom, etc.
