Results 1 to 18 of 18
  1. Does anyone know what kind of protection RaiPlay uses ? I tried all possible tools, streamlink, ffmpeg, raiplay-dl, yt-dlp, none of them seem to work. Yes, I am in Italy with a valid Italian IP and I can view the show just fine in the browser.
    It's this show, apparently RaiPlay is the only place with the Italian-dubbed version which I really like:
    https://www.raiplay.it/programmi/foodielove
  2. DRM.
    Need access.
  3. key
    889313faa7d543a8a1bf570d7f2044bd:6599997083dbfd7eb26a539c586b6126
    no time now to test it how to download
  4. I couldn't get this thing to run, but try this, it might download.
    https://github.com/xhlove/XstreamDL-CLI
  5. Originally Posted by [ss]vegeta View Post
    Thanks. How would I pass it my authentication information ? That link isn't available on RaiPlay unless I authenticate
  6. Originally Posted by ajones219 View Post
    Use developer tools, network tab to get the mpd/ism link.
    That link is accessible without authentication.
    Pass that link to Xstream, don't pass the normal link.
  7. Thanks, I already had those. The MPD file is https://dashaz-dc-euwe.akamaized.net/subtl_proxy/840d290b-b1ba-4b27-839d-992374536941/...1200-2400).mpd
    but when I try putting it in that script it errors out as below. I tried with the key lomero posted above and without it, same error:
    c:\rai2>C:\Users\dev\AppData\Local\Programs\Python \Python39\python.exe -m XstreamDL_CLI.cli --key 889313faa7d543a8a1bf570d7f2044bd:6599997083dbfd7eb 26a539c586b6126
    Paste your URL/FILE/FOLDER string at the end of commands, plz.
    Ctrl C to exit or input here:https://dashaz-dc-euwe.akamaized.net/subtl_proxy/840d290b-b1ba-4b27-839d-992374536941/...1200-2400).mpd
    2021-11-24 18:54:48,387 XstreamDL log.py 41 : INFO log file -> C:/rai2/logs/XstreamDL-2021-11-24_185448.log
    2021-11-24 18:54:48,392 XstreamDL cli.py 152 : INFO set URI to ['https://dashaz-dc-euwe.akamaized.net/subtl_proxy/840d290b-b1ba-4b27-839d-992374536941/20210203162140_13931974.ism/manifest(format=mpd-time-csf,filter=medium_1200-2400).mpd']
    File "C:\Users\dev\AppData\Local\Programs\Python\Python 39\lib\runpy.py", line 197, in _run_module_as_main
    return _run_code(code, main_globals, None,
    File "C:\Users\dev\AppData\Local\Programs\Python\Python 39\lib\runpy.py", line 87, in _run_code
    exec(code, run_globals)
    File "c:\rai2\XstreamDL_CLI\cli.py", line 160, in <module>
    main()
    File "c:\rai2\XstreamDL_CLI\cli.py", line 154, in main
    daemon.daemon()
    File "c:\rai2\XstreamDL_CLI\daemon.py", line 30, in daemon
    streams = extractor.fetch_metadata(self.args.URI[0])
    File "c:\rai2\XstreamDL_CLI\extractor.py", line 48, in fetch_metadata
    return self.raw2streams('url', *loop.run_until_complete(self.fetch(uri)), parent_stream)
    File "c:\rai2\XstreamDL_CLI\extractor.py", line 95, in raw2streams
    return self.parse_as_dash(uri_type, uri, content, parent_stream)
    File "c:\rai2\XstreamDL_CLI\extractor.py", line 127, in parse_as_dash
    streams = self.parser.parse(uri, content)
    File "c:\rai2\XstreamDL_CLI\extractors\dash\parser. py", line 132, in parse
    return self.walk_period(mpd, uri_item.new_base_url(base_url))
    File "c:\rai2\XstreamDL_CLI\extractors\dash\parser. py", line 149, in walk_period
    _streams = self.walk_adaptationset(period, len(streams), uri_item.new_base_url(base_url))
    File "c:\rai2\XstreamDL_CLI\extractors\dash\parser. py", line 177, in walk_adaptationset
    _streams = self.walk_representation(adaptationset, period, sindex + len(streams), current_uri_item)
    File "c:\rai2\XstreamDL_CLI\extractors\dash\parser. py", line 236, in walk_representation
    self.walk_segmenttemplate(representation, period, stream)
    File "c:\rai2\XstreamDL_CLI\extractors\dash\parser. py", line 294, in walk_segmenttemplate
    self.generate_v1(period, representation.id, segmenttemplates[0], stream)
    File "c:\rai2\XstreamDL_CLI\extractors\dash\parser. py", line 401, in generate_v1
    interval = float(int(st.duration) / int(st.timescale))
    ZeroDivisionError: division by zero
  8. Deceased
    Dec 2007
    The MPD file is
    The bitrate filter can be removed from the mpd url, leaving;
    https://dashaz-dc-euwe.akamaized.net/subtl_proxy/840d290b-b1ba-4b27-839d-992374536941/20210203162140_13931974.ism/manifest(format=mpd-time-csf).mpd
    For some reason, I get the following error with yt-dlp, regardless of the switches used;
    ERROR: An extractor error has occurred. (caused by KeyError('s')); please report this issue on  https://github.com/yt-dlp/yt-dlp. Make sure you are using the latest version; see  https://github.com/yt-dlp/yt-dlp  on how to update. Be sure to call yt-dlp with the --verbose flag and include its complete output.
    However, an old patched version of youtube-dl works fine;
    I:\youtube-dl-mod "https://dashaz-dc-euwe.akamaized.net/subtl_proxy/840d290b-b1ba-4b27-839d-992374536941/20210203162140_13931974.ism/manifest(format=mpd-time-csf).mpd" -F
    [generic] manifest_1631345527812: Requesting header
    WARNING: Falling back on generic information extractor.
    [generic] manifest_1631345527812: Downloading webpage
    [generic] manifest_1631345527812: Extracting information
    [info] Available formats for manifest_1631345527812:
    format code      extension  resolution note
    5_A_audio_ita_1  m4a        audio only [Italiano] DASH audio  189k , m4a_dash container, mp4a.40.2 (44100Hz)
    5_A_audio_vor_1  m4a        audio only [V.O.] DASH audio  189k , m4a_dash container, mp4a.40.2 (44100Hz)
    1_V_video_1      mp4        736x414    DASH video 1199k , mp4_dash container, avc1.4D401F, 25fps, video only
    1_V_video_4      mp4        1024x576   DASH video 1799k , mp4_dash container, avc1.4D401F, 25fps, video only
    1_V_video_5      mp4        1280x720   DASH video 2399k , mp4_dash container, avc1.4D4028, 25fps, video only
    1_V_video_2      mp4        1440x810   DASH video 3599k , mp4_dash container, avc1.4D4029, 25fps, video only
    1_V_video_3      mp4        1920x1080  DASH video 4999k , mp4_dash container, avc1.640033, 25fps, video only (best)
    I:\youtube-dl-mod "https://dashaz-dc-euwe.akamaized.net/subtl_proxy/840d290b-b1ba-4b27-839d-992374536941/20210203162140_13931974.ism/manifest(format=mpd-time-csf).mpd" --fixup never -f 5_A_audio_ita_1 -o I:\5_A_audio_ita_1.m4a
    [dashsegments] Total fragments: 972
    [download] Destination: I:\5_A_audio_ita_1.m4a
    [download]   3.1% of ~44.35MiB at 124.12KiB/s ETA 10:44
  9. Where can I get that version ? Is the downloaded file encrypted ?
  10. Deceased
    Dec 2007
    Someone will probably refer you to a source. If not, post again later.
    Yes, but see post #3 of this thread.
  11. Deceased
    Dec 2007
    It seems that yt-dlp may work if the mpd url is adjusted, removing the "subtl_proxy" part of the url;
    https://dashaz-dc-euwe.akamaized.net/840d290b-b1ba-4b27-839d-992374536941/20210203162140_13931974.ism/manifest(format=mpd-time-csf).mpd
    Command line to list sources;
    yt-dlp "https://dashaz-dc-euwe.akamaized.net/840d290b-b1ba-4b27-839d-992374536941/20210203162140_13931974.ism/manifest(format=mpd-time-csf).mpd" -F --allow-unplayable-formats
  12. Thank you everyone, using the information from this thread I was able to download the video/audio files, decrypt them, add subtitles and mux them all together. Really amazing - thank you all very much!
    I ended up using yt-dlp as blimey suggested - thank you again
  13. I may have spoken too soon. that key only worked on the first episode, is it different keys for each episode and if so, how do I get them ?
  14. nevermind again, I found widevine-guesser and an older widevine dll and was able to get the keys myself, thanks again everyone!
  15. yea, each episode (or video) need a proper key
  16. Originally Posted by blimey View Post
    Nice find
  17. Originally Posted by blimey View Post
    respect++
