mpd url
the license url is embedded in manifest how to grab its auth bearer tokenCode:https://drvideo-ak.akamaized.net/video-sg3/53ae84d1-8b41-4323-8be9-a0fe5ddbf130/5255.ism/manifest(format=mpd-time-csf)
it does not appear in headers
what kind of response do you expect if you open the same topic again without providing any relevant information?
Did you post the same url elsewhere on the net, but with the Authorization: Bearer value included?
At the very bottom of the following page, from google cache, the same url is included, but also with an Authorization: Bearer value
https://archive.md/5EbEP
Code:Authorization: Bearer eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJ1dWlkIjoiNzgzYTc0Zjk0M2E0NDAyMGFhZTFhYTMwYTZhOWU3YmEiLCJtYWlsYm94IjoiaGFzZXJlODgxM0BjeWFkcC5jb20iLCJpYXQiOjE2MzE4MTIzODB9.jQPPzNUkFOsZvqKS2OYRSblJkJS4aPBzJuZyle_dY0U
Even though the license url is embedded in manifest, and that is how the mobile player gets the license url, the license url still has to be independently used by the mobile player.
That request, when the mobile player actually uses the license url, is where the header will contain the Authorization: Bearer value.
If you can't find that request, look at all of the requests in all of the network traffic. If it still can't be found, you're out of luck.
Widevine help
By Stevo1987 in forum Video Streaming DownloadingReplies: 16Last Post: 27th Aug 2022, 12:08 -
Extracting token for m3u8 stream
By aeregeneratel38 in forum Video Streaming DownloadingReplies: 3Last Post: 27th May 2021, 12:20 -
Extracting token for stream url.
By aeregeneratel38 in forum DVB / IPTVReplies: 0Last Post: 26th May 2021, 09:41 -
Need help to get stream with token
By bayd in forum Video Streaming DownloadingReplies: 2Last Post: 17th Dec 2019, 13:42 -
FFmpeg transcode .m3u8 return (401 Unauthorized authorization failed)
By qoraiche in forum Video Streaming DownloadingReplies: 3Last Post: 9th Nov 2017, 19:42
