Results 1 to 13 of 13
    Nov 2021
    india
    mpd url
    https://drvideo-ak.akamaized.net/video-sg3/53ae84d1-8b41-4323-8be9-a0fe5ddbf130/5255.ism/manifest(format=mpd-time-csf)
    lic url embedded in manifest
    https://drvideo.keydelivery.mediaservices.windows.net/Widevine/?kid=a09a150f-4f3b-407e-b034-54a13970202b
    pssh
    AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEKCaFQ 9PO0B+sDRUoTlwICs=
    Headers
    Dr-Platform: android
    Dr-Dv: m.2061a6e23daeed98
    course-id: 1
    Dr-UID: 6197bdf7aa8ded1766241523 - MFREE
    Dr-App: marrow
    Dr-Dv-ENC: obexJBKqdVvXmpv7H7fvc7J+dR0HueAT1fYe3edYg98ysexpH0 uzT1dPhgJLxFv7FA==
    Dr-Dv-Model: M2007J17I
    Dr-Token: .eJxVztEKwjAMheF3ybXI2m7p5suUaDIouKVksl2I725HQfD25-Nw3pAyww3QTfHOcyQaWdhFRN-7wQe4AFti2fNDKluuvkNHKD4wifA0NkClpF1sy7pWFbqhZd3-6s-eS2SmRyvlSa9ZbamZVjatjz5fps8vnA.FHlPdw.cU9iv7UGWbB z-O5eqWVeewLMDSY
    Dr-App-Version: 308
    Dr-Dv-Ts: 1637515407460
    User-Agent: Marrow/7.15.1 (com.marrow; build:308; Android 11(30); Device)
    Accept-Encoding: gzip
    Host: drvideo-ak.akamaized.net
    Connection: Keep-Alive
    Authorization:  Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJodHRwczpcL1wvbWVkaWNhbC5wcmVwbGFkZGVyLmNvbSIsImF1ZCI6InVybjpwcmVtaXVtIiwiZXhwIjoxNjM3NjkxNzAwLCJuYmYiOjE2Mzc2OTE0MDB9.jZBnTZxNKFd3Kwd13JbcywVoYb36qpwRY_WcTPkX4Dg
    unable to decrypt please help
  2. Deceased
    Dec 2007
    The important header value begins with: Authorization Bearer ey ...
    Which you don't show in your list. That header value needs to be fresh, if it is even more than a couple of minutes old, it will have expired.
    You can use an azure demo player to test;
    https://ampdemo.azureedge.net/
    Enter the mpd url, and choose update player.
    Use a browser extension like modheader to add the "Authorization Bearer" header value.
  3. if you play video into some pc browser you get Authorization Bearer on dev tool
    anyway best way is write here video link and login if needed to play.
  4. or also play video on your windows browser, then save and share cookie. with this don't need login data.
    Nov 2021
    india
    https://video.prepladder.com/2019-09-08_11371_12651/Lipoproteins-10786/dash.mpd
    https://widevine-dash.ezdrm.com/widevine-php/widevine-foreignkey.php?pX=0E4BB2&CustomData=c423fa0b81ebb470cd2431d3431ae24cb2f92736ee928636d7ef826317427debprepladder
    Authorization: Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJod HRwczpcL1wvbWVkaWNhbC5wcmVwbGFkZGVyLmNvbSIsImF1ZCI 6InVybjpwcmVtaXVtIiwiZXhwIjoxNjM3NjkxNzAwLCJuYmYiO jE2Mzc2OTE0MDB9.jZBnTZxNKFd3Kwd13JbcywVoYb36qpwRY_ WcTPkX4Dg
    securityLevel: L3
    Content-Type: application/octet-stream
    User-Agent: prepladder/2.0.79-p (Linux;Android 11) ExoPlayerLib/2.10.8
    Content-Length: 2159
    Host: widevine-dash.ezdrm.com
    try this
    Nov 2021
    india
    https://widevine-dash.ezdrm.com/widevine-php/widevine-foreignkey.php?pX=0E4BB2&CustomD...7debprepladder
    securityLevel: L3
    try this
  7. Deceased
    Dec 2007
    That's a different content source than the one you mentioned before.
    The first source uses azure (mediaservices<dot>windows<dot>net).
    The second uses ezdrm.
    The azure source should also have an "Authorization: Bearer" header value.
    Why are you mixing them? Did you give up on the first source, and now just want to move on to a different source?
  8. Originally Posted by codehound View Post
    For starters, if its WV it needs a completely different approach anyway- give us the url of the video
    the main rule if you want an answer to your question
    Nov 2021
    india
    I could not find auth bearer there
    could u help me with second one
    Nov 2021
    india
    this shit runs only on app i dont have video url
  11. lic url is truncated
    put full link into code tag
    [Attachment 61970 - Click to enlarge]
    and PSSH needed
    Nov 2021
    india
    and PSSH needed
    I have made the edits in original post
    and thats the full url thats all i see in manifest
  13. Originally Posted by birbal1 View Post
    try to use traffic sniffer Debug Proxy
    https://youtu.be/Gr2Zx4IJSVQ
    https://techwiser.com/wireshark-alternatives-for-android/
