Are Foinnex hyper thin and hyper light (2 mm) 8K@60 HDMI cables the best for Gimbals?
Watch:
https://www.aliexpress.com/item/1005002244267188.html?spm=a2g0o.detail.1000060.2.3fae4...:%223339%22%7D
I always use them during I record videos via HDMI on Gimbal.
				Results 1 to 30 of 32
	Science says "Nope".
 You want thin & lite, go with fiber optic transceivers.
	Corni,
 Fiber optics is good for very long cables. (TV studios often need very long cables)
 For handheld gimbals between 1m and 2 m is more than enough. Optical cables have no real practical advantages in such short distance.
 I have for example optical internet since 2009. How is it possible that you have low speed Internet in Texas? I simply can't believe that. Doesn't you have optical internet even in the toilets in villages? I have never been in Texas, just in a short trip in New York and LA, but there were optical internet and fast mobile internet even Wi-fi in these places. What happened with Texas ?Last edited by Truthler; 23rd Nov 2021 at 08:56.
	Let's see the optical HDMI cables
 https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=optical+hdm...hdmi&_osacat=0
 Optical cables are usually thinner and lighter than traditional copper-based HDMI cables, but they are not thinner or lighter than the 8K@60 Foinnex copper cables.
 And optical cables have proven advantages only for long cables.Last edited by Truthler; 23rd Nov 2021 at 09:39.
	You need to stop believing everything advertisers tell you.
 Maybe you don't really care about the signal reliability. Your loss.
	Depends on how it is built (gauge, winds, connection materials, shielding, etc). And I wouldn't trust that one to be reliable, no.
	I already ordered an optical HDMI cable, I will bring it tomorrow and I will compare it with the very thin copper cable. And I will post the result in pictures.
 But why are copper wires in an OPTICAL CABLE? I know its chipset needs electric power transmission too, but I think there is data exchange too.Last edited by Truthler; 23rd Nov 2021 at 15:48.
	Corni!
 After the HDMI=> USB3 transformation, the signal will go to the copper USB3 cable, than it travel on copper vire in the computer... So where will be the adventage of light speed?
	Corni, at the shop I could chose between 8 type of Optical HDMI cables, all of them were bulkier/ ticker and heavier than the foinnex cables.
	It seems you still haven't learned that size and weight are not the only, or even MOST, important factors when choosing a video cable.
 But if you like/want those particular cables, do what you will.
 Not going to convince me of any benefit in using them - I have seen firsthand too many instances of "ultrathin" cables failing often and not living up to their hype.
 And ultimately it is naive to think you can get around plain physical constraints, like magic's "something from nothing".
 Also, I find it odd that anyone would strap ANY cabling to a cam that was gimballed, as that would counteract the free range of motion expected.
 But do have fun with your "Foinnex".
 @Nizzon, thanks for that interesting find!
	Yes. The best cable typically means the cable that has the best construction and delivers the highest-quality signal. Physics dictates that passive, ultra-thin copper wire HDMI cables can't be the best, even at a 2m length. The wires are too thin and probably lack adequate shielding. Ignore list: hello_hello, tried, TechLord, Snoopy329
	Tomorrow I will compare the hyper thin copper cable with the optical cable.
	How so? With that tester box? Or are you eyeballing it? Under what stresses?
 But you go ahead and do that.
	Very bad news about optical cables:
 https://www.youtube.com/watch?v=0Tfd5ygqAts
	No. Bad news about shoddily-manufactured cables. Simple answer: don't buy those cheap-ass brands.
	Corni, Can you explain it please?
 What is the advantage of optical cables, (if we speak about short distance). As my last posted video reveals that the optical cables are also vulnerable like their copper opponents.
 And the main question: what is the adventage of optical cables, if I had to transform the HDMI to USB3 (Cam link 4K) and its USB3 cable is a copper based cable, and let's don't forget the computer motherboards have extreme thin integrated copper wires? (Motherboards are copper wired systems)Last edited by Truthler; 25th Nov 2021 at 06:09.
	Nice try, but the layouts for circuit boards are designed to minimize the effects of electromagnetic interference.
 https://www.vse.com/blog/2021/01/28/how-to-avoid-electromagnetic-interference-emi-in-p...ircuit-boards/Ignore list: hello_hello, tried, TechLord, Snoopy329
	The main EM problem with copper cables is cross-talk. Shielding is used to reduce that problem with copper cables, but there is no cross-talk with optical cables.
 Circuit board layouts are designed to reduce cross-talk too. However, this whole circuit board discussion is just a distraction.
 You were given good advice. Take it or don't take it. There is no benefit in arguing this point any further.Ignore list: hello_hello, tried, TechLord, Snoopy329
	OK, I'll respond to some of your past posts that I hadn't previously responded to...
 Post (paraphrasing):
 They aren't. They are in a HYBRID cable. The hybrid cable is PROBABLY designed so that it can provide power (not yet possible with pure optical). Possibly also ethernet (part of the extended HDMI spec).#8 - Why are copper wires in an optical cable?
 There is not one in this instance (short cable lengths). There WOULD be one with longer lengths.#9 - If converting anyway, where is the advantage of optical speed?
 OK, but that may just be the shop you chose. Regardless, thinness is not often the prime motivator for choosing a cable. Nor should it be: (assuming cost is not a majore constraint) RELIABILITY is most important.#10 - At the shop, all opticals were heavier bulkier than the foinnex cables?
 How did that go, based on the rigorous criteria I suggested to you in my lengthy PM response?#11 - tomorrow I will compare hyper-thin foinnex cable.
 First, NO. Plenty of pros do this as well. There is nothing inherently "bad" with a lossy codec, it is just a certain compromise. If the compromise is worth it for the workflow/situation, that is fine. This often has little to do with end-use "detail", especially as regards cable quality. And memory cards are perfectly fine, as long as they are fast enough, large enough, and are reliable (not easily corrupted) - this is all testable beforehand. Second, Ha, ha! Third, why are you giving shade to barbarians?#12 - Only barbarians shoot video with lossy codecs on memory cards.
 It isn't the cable weight that I would be concerned about in a gimballed cam stabilizer setup, it is the fact that cables are connected (anchored) on 2 ends, and that means there is a tendency for a cable to RESIST motion (similar to a spring). The whole point of the gimballed setup is to allow gimbal motion to counteract the unwanted body/cam motion. If it is being resisted, it cannot properly do that.#12 - I can autocalibrate the gimbal for that weight too.
 1. Less signal loss vs cable length (not an issue for short cables). 2. Immunity to EMI/RFI. 3. Resistance to weather elements (especially water). 4. (Usually) thinness.#21 - Can you explain please the advantage of optical cables?
 Disadvantage? (you didn't ask, but I thought I should say for fairness) - 1. Fragility, especially regarding bends/kinks, 2. Cables usually require transducers (electrical <-->optical and optical<-->electrical) to operate and this must be accounted for.
 Yes, they are not perfect. And cheapo manufacturers make shoddy cables, whether electrical or optical. And those will show up on test reports. BUT, in the case of optical cables, it almost always is an issue with the connector/transducer. If the cable itself were of such low quality (such as with a kink/break), it would not pass ANY signal and would be obvious.#21 - optical cables are also vulnerable.
 Solution: buy good quality cables from well-known manufacturer/distributors. Then test them.
 Motherboards are going to be a link in the chain REGARDLESS of the choice of cable, and so should not factor into a comparison of cables. If motherboards were as "vulnerable" as you are implying, we wouldn't be able to be using the hundreds of millions that we all are using. And if there is a possibility of EMI/RFI, that can be tested for, and counteracted. Since both cables and Mobos, etc. are dealing with DIGITAL signals, if a reduction of 10-15% results in raising the threshold enough beyond error correction, then there is no worry, as it will be corrected.#23,25 - motherboard traces...blah,blah,blah...
 OK, so how about you stop going off on side topics? The OP was what some of us might think of those cables for that stated scenario. I and others gave you our educated opinions and recommendations/caveats, along with some scientific justification for those evaluations. If this all was truly a question, it has been answered.
	Wait, so you are using a gimballed stabilizer system AND an in-cam digital optical stabilizer ("steadyhot".sic) at the same time?
 SMH...
  Best reasonably priced HDMI cables for high bitrate capture?By Big Ry in forum Video Streaming DownloadingReplies: 7Last Post: 28th Aug 2020, 18:21
  Can a very thin and long HDMI cable add latency?By RoyZ7 in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2020, 23:37
  Which HDMI Coiled CablesBy therock003 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2020, 11:58
  Are there any HDMI to USB cables for using a camcorder- as a webcam?By videofan70 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 2nd Mar 2020, 13:37
  I need hdmi cables for ezcap 284By DreiK in forum Capturing and VCRReplies: 0Last Post: 14th Nov 2018, 15:17
