Hi, thanks for letting me join the forum.
I've searched for the problem but couldn't find it and I hope this is the right thread.
Basically, I have a Panasonic DMR-EZ45V. I've been using it successfully for the last couple of years to transfer VHS to DVD.
I have it connected to an old TV\Video player.
Suddenly tonight, it now no longer displays the tapes.
They play (I can see the counter running).
The tapes play on a different VCR.
However, multiple different tapes now only show a blue screen.
I have swapped the Scart cable
I have switched from AV1 to AV2
I have changed sources on the tv.
They worked perfectly well before and I have changed nothing.
The only thing I can think of is that the Panasonic has got cold?!
I use it in the garage and the temperature tonight was minus something.
Could the cold affect the device?
Many thanks for your help.
Results 1 to 18 of 18
Did you try cleaning the video heads?
You need to test all your outputs in the workflow one at a time and see which one is not outputting the signal to locate the culprit component, preferably use a TV or video monitor, Using the capture card adds a layer of difficulty especially for non tech savvies.
Thanks, I'm not using a capture card though. No signal leaves the unit.... it plays but it plays a full blue screen.
I'm not even sure if there is audio -
Does the TV have an option to turn off the "blue back"? It may be receiving a garbled signal from the VCR that it's muting. If you could see the actual output, you may be able to troubleshoot further.
The UK manual for DMR-EZ45V refers to a Grey Background that can be turned on or off, not a blue one. Maybe the VCR side has its own blue screen that can't be disabled, but it sounds like it's being generated by the TV.My YouTube channel with little clips: vhs-decode, comparing TBC, etc. -
I've moved the DVR indoors and connected the same way but to a newer tv.
I have the volume up on this one and can hear that the audio is there so no problems on that front, but this time the picture is black.
I'm going spare! -
Read your TV's and VCR manuals to make a successful connection, It sounds like wrong display settings to me. Just take it easy, this kind of stuff can be frustrating but with a step by step approach I mentioned above you will figure it out.
I am now wondering if it's a tracking issue as whilst watching a completely black screen and listening to perfect audio, the screen started to flicker and glipses of a picture flicked on the screen.
It didn't get any better than a flicker but would this lead me in another direction when troubleshooting? -
RESOLVED: Pressed the "Input Select" button on the DVR.
I was on "1" which was audio only.
Every other selection (AV1, AV2, DV etc) worked.
I feel foolish but hopefully this will help someone else! -
I don't get it. You're talking about the external input selection of the Panasonic DMR-EZ45V? But you're using it to play the tapes, so the Input Select should only change what's shown before you hit Play on the VCR side.
And you said you'd already tried AV1 and AV2...
Well thats what I thought so I'm not second guessing it.
I thought the INPUT to the DVR would be irelevent to the output onto the TV, however, changing it worked!
What Video Capture Hardware/Software Doesn't Blue Screen?
By ThePolaroidMan in forum Capturing and VCRReplies: 23Last Post: 25th Nov 2021, 17:37 -
Blue Screen Dropouts On Capture
By TazDave in forum Capturing and VCRReplies: 2Last Post: 26th Sep 2020, 20:00 -
VSDC - Unable to Crop or Split Video (blue screen overlay on menu)
By cooker6583 in forum EditingReplies: 0Last Post: 11th Mar 2019, 10:09 -
Burning screen capture video to Blue-Ray
By sonoman in forum Authoring (Blu-ray)Replies: 5Last Post: 5th Feb 2018, 12:05 -
Is it normal for a TBC to be unable to display the blue screen of a VCR?
By digicube in forum Capturing and VCRReplies: 6Last Post: 13th Jan 2017, 11:48
