1. Its just based on trial and error. Normally the headers are required to provide information about the content or the subscriber and expiry time. Ones that dont require headers normally have that information in the license server url as a query string. And theres others that require a few requests back and forth to get the keys.
2. You could try using the x-dt-auth-token from another video and get the right pssh from the saved mpd and see if that works, but it probably wont. you might have to find that episode elsewhere....
Results 31 to 60 of 70
ok, thanks for these detailled informations!
I already tried with the pssh and a fresh token but as supposed it doesn't work! not a problem anyway
thank you -
Hello
now after a few months without trying to download anything from this site, I tried today with all the step which were working before and I have the following error with the online tool: "Incorrect padding". Does someone have any idea?
thanks by advance -
thank you for answer
here is the link
I used this psshCode:https://www.6play.fr/top-chef-les-grands-duels-p_16435/chloe-charles-gianmarco-gorni-c_12939236
and this license serverCode:AAAAbXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAE0IARIQMs9YcnLPAV7NNiTMLWjvbRoIY2FzdGxhYnMiJGV5SmhjM05sZEVsa0lqb2lZMnhwY0Y4eE1qa3pPVEl6TmlKOTIHZGVmYXVsdA
Code:https://lic.drmtoday.com/license-proxy-widevine/cenc/?specConform=true
yes I used a "x-dt-auth-token:" (I will not give one here because it changes regularly)
and add == to end on psshCode:
32cf587272cf015ecd3624cc2d68ef6d:05996712a109f00c4a4d254317c694be 24f4f2043486476ab738e6f33253f69a:718ddb97f3bd83685cdf00554831b8e9
thank you so much gentlemen! it works perfectly with those added =
but just any question: what is a multiple of 4 with the added "="? the pssh converted in hexadecimal or something like that?
thank you for your help guys, I really appreciate that -
The number of characters in the PSSH, divided by 4, should be an integer.
[Attachment 64616 - Click to enlarge] -
perfect, thanks a lot for those complete explanations!
PS: excel always seems to be a powerfull tool in any case! -
hi , i want to download a video but i found only key for 540p and nothing for 720p , here's the link mpd :
the license :Code:https://6play.vod.6cloud.fr/m6web/output/2/f/8/2f8c60f217b9623d414e8543db7fc9d9d1e5acb66f7c1c6f84c5bd78459b4bdd/static/c12896887_web_drm_720p_dash_v1.mpd
KID :Code:https://lic.drmtoday.com/license-proxy-widevine/cenc/
pssh :Code:D4553FDB8789C176338F56B750711AA0
Thanks for your helpCode:AAAAbXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAE0IARIQ1FU/24eJwXYzj1a3UHEaoBoIY2FzdGxhYnMiJGV5SmhjM05sZEVsa0lqb2lZMnhwY0Y4eE1qZzVOamc0TnlKOTIHZGVmYXVsdA==
Yes i know , i 've download video in 720p but for decrypt i found only key for 540p version and nothing for 720p ..
there's another key different of 540p version ...
Thanks for your help -
This is the same i've had posted before
MPD :In the MPD info you'll see KID :Code:https://6play.vod.6cloud.fr/m6web/output/2/f/8/2f8c60f217b9623d414e8543db7fc9d9d1e5acb66f7c1c6f84c5bd78459b4bdd/static/c12896887_web_drm_720p_dash_v1.mpd
So another key .. Maybe Widevine L1 ...Code:D4553FDB8789C176338F56B750711AA0
The mpd that you posted has the following streams
the key to decrypt isEXT RESOLUTION FPS │ TBR PROTO │ VCODEC VBR ACODEC ABR ASR MORE INFO
audio1=96000 m4a audio only │ 96k dash │ audio only mp4a.40.2 96k 48000Hz [fr] DASH audio, m4a_dash
video=299970 mp4 400x224 25 │ 299k dash │ avc1.42C01E 299k video only DASH video, mp4_dash
video=800009 mp4 640x360 25 │ 800k dash │ avc1.42C01E 800k video only DASH video, mp4_dash
video=1499940 mp4 720x404 25 │ 1499k dash │ avc1.42C01E 1499k video only DASH video, mp4_dash
video=2099858 mp4 960x540 25 │ 2099k dash │ avc1.64001F 2099k video only DASH video, mp4_dash
video=3149762 mp4 1280x720 25 │ 3149k dash │ avc1.64001F 3149k video only DASH video, mp4_dash
Download (choose what ever resolution you desire from the list) and decrypt with the key.b896f9a113e3d06fe30066d2e1cf25bc:30175c9a0d3ea92f8 3bc202385852bc3 -
Thanks for your answer , but like i said before this key
is only for SD version ( up to 540p ) , for 720p there's another key , you can see in the mpd info , KID is different ...Code:b896f9a113e3d06fe30066d2e1cf25bc:30175c9a0d3ea92f8 3bc202385852bc3
confirmed. this keys does not work for 720p
anyway kid from mpd is the same as key above
[Attachment 64866 - Click to enlarge] -
There are 2 @ kids in the manifest. The one chosen (D4553FDB-8789-C176-338F-56B750711AA0) is for the low quality
The one required, as lomero pointed out, is B896F9A1-13E3-D06F-E300-66D2E1CF25BC.
The pssh to use is
AAAAbXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAE0IARIQuJ b5oRPj0G/jAGbS4c8lvBoIY2FzdGxhYnMiJGV5SmhjM05sZEVsa0lqb2lZM nhwY0Y4eE1qZzVOamc0TnlKOTIHZGVmYXVsdA==Last edited by jack_666; 19th May 2022 at 16:07.
Is it possible to get keys for https://www.6play.fr/incroyables-transformations-p_13415/emma-sabrina-sabine-c_12942785 best quality please ? thank you in adv!
hello olmads
your key
Code:041c26ac2bda9a0f80960977d6fef19e:131f086252042ae02b42aad85a3163e6
its the other way around, jack, d4553fdb-8789-c176-338f-56b750711aa0 is for the high quality
Yeh you're right, the 720p quality now needs a L1 cdmCode:>mp4dump 6play.720p.mp4 | findstr /I kid default_KID = [d4 55 3f db 87 89 c1 76 33 8f 56 b7 50 71 1a a0]Last edited by ElCap; 19th May 2022 at 19:34. Reason: updated
yes bader. and here your keys, about your video on post#50
Code:b896f9a113e3d06fe30066d2e1cf25bc:30175c9a0d3ea92f83bc202385852bc3 d4553fdb8789c176338f56b750711aa0:ebfeb2e27d71293a371fe21e16bea816
Downloading 6play.fr in HD
By dzadzen in forum Video Streaming DownloadingReplies: 0Last Post: 2nd May 2021, 18:07 -
Downloading from 6Play
By Hakunamatata67 in forum Video Streaming DownloadingReplies: 8Last Post: 20th Jul 2019, 02:23
