Hi, dear all.
---> https://www.7-zip.org/
Concerning about 7-zip, does exist ( being possible to set ) other values / sizes ( volumes ) when I split one file, besides the commonly used ones?
[Attachment 61944 - Click to enlarge]
For example: does it possible to use GB, TB, kB, KiB or other unusual ones concerning splitting options on 7-Zip settings?
I mean, if I want to use GB, how can I put that values / volumes on 7-Zip box options?
Eg: splitting large files into 7.7 GB pieces. How can I write this size / volume in a way that 7-Zip will accept exactly this value?
Thanks for your time.
Best regards.
Just type the value you want in the box,(eg 7.7gb).
Re-compress files in ZIP or RAR format to match existing incomplete archive
By abolibibelot in forum ComputerReplies: 14Last Post: 2nd Mar 2026, 08:58 -
Splitting videos into separate files- PLEASE HELP
By Kelly in forum MacReplies: 8Last Post: 26th Aug 2019, 23:20 -
how can you install LAVFilters-0.73.1-x64.zip? mp4 files do not play.
By sommers in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2018, 09:37 -
Splitting MKV files
By Dabuss55 in forum EditingReplies: 1Last Post: 10th Jul 2018, 07:20 -
Only half the audio loads in Premiere Pro (some files) (Splitting files)
By The_Sociopath in forum EditingReplies: 1Last Post: 26th Jan 2017, 14:25
