It has 100 asynchronous Subtitles in Indonesian and 100 Synchronized Subtitles into English
Is there a script that adjusts the subtitle of the first line to be synchronous
SUB.Indonesian.srt
SUB.English.srtCode:1 00:00:02,040 --> 00:00:04,410 "Episode Satu" 2 00:00:05,179 --> 00:00:07,610 "Tujuh tahun lalu" 3 00:00:23,859 --> 00:00:25,800 Ada apa? Kenapa kalian tidak memakai baju olahraga?
after.sync.srtCode:1 00:00:07,551 --> 00:00:09,920 (Episode 1) 2 00:00:10,691 --> 00:00:13,231 (7 years ago) 3 00:00:29,440 --> 00:00:31,381 What's going on? Why aren't you in your gym clothes?
Code:1 00:00:07,551 --> 00:00:09,921 "Episode Satu" 2 00:00:10,690 --> 00:00:13,121 "Tujuh tahun lalu" 3 00:00:29,370 --> 00:00:31,311 Ada apa? Kenapa kalian tidak memakai baju olahraga?
batch
SUB.English_%%x.srt SUB.Indonesian_%%x.srt after.sync_%%x.srt
I know a Subtitle Edit , but it only works with one subtitle
All I need is sync from the first line only. Using Python Any suggestions?
this is an example calling for one pair, that could be fed from something, not sure how you store those srt's
Code:def sec2time(sec): ''' Convert seconds to 'D days, HH:MM:SS.FFF' ''' m, s = divmod(sec, 60) h, m = divmod(m, 60) d, h = divmod(h, 24) pattern = '%%02d:%%02d:%%0%d.%df' % (6, 3) if d == 0: return pattern % (h, m, s) return (f'{h:d}:{m:02d}:{s:02d}') def time2sec(time): time = time.replace(',','.') h, m, s = map(float, time.split(':')) return h * 3600 + m * 60 + s def get_first_time(filename): with open(filename, 'r+') as f: for line in f: if '-->' in line: time = line.split('-->')[0].strip() return time2sec(time) def sync_first_sub(used_subtitles_srt, for_first_time_srt, new_srt): delay_in_sec = get_first_time(for_first_time_srt) - get_first_time(used_subtitles_srt) with open(used_subtitles_srt, 'r+') as f, open(new_srt, 'w') as w: for line in f: if '-->' in line: new_start_sec = time2sec(line.split('-->')[0].strip()) + delay_in_sec new_start_time = sec2time(new_start_sec).replace('.',',') new_end_sec = time2sec(line.split('-->')[1].strip()) + delay_in_sec new_end_time = sec2time(new_end_sec).replace('.',',') w.write(new_start_time+ ' --> ' + new_end_time + '\n') else: w.write(line) sync_first_sub(used_subtitles_srt=r'F:\path\SUB.Indonesian.srt', for_first_time_srt=r'F:\path\SUB.English.srt', new_srt=r'F:\path\after_sync.srt')Last edited by _Al_; 17th Nov 2021 at 23:37.
After trying, an error message appears
https://forum.videohelp.com/images/imgfiles/UNjZoKk.jpg
If you do a script that works on which path is better
Example
batch
Code:echo off sync.py "SUB.Indonesian.srt" "SUB.English.srt" "after_sync.srt" pause
you need three full correct paths for that script when calling sync_first_sub function
How do you have those srt's in your folder or folders and how are they named?
for that to make it work, instead of that calling sync_first_sub() you can paste::Code:echo off sync.py "SUB.Indonesian.srt" "SUB.English.srt" "after_sync.srt" pause
Code:if __name__ == '__main__': import os import sys source_paths = [] if len(sys.argv) > 1: for i, path in enumerate(sys.argv[1:]): if i < 2 and not os.path.isfile(path): raise ValueError(f'Not a valid path or file does not exist: {path}') source_paths.append(path) if i < 2: raise ValueError(f'Three path arguments needed') source_paths = source_paths[0:3] source_paths = [os.path.abspath(path) for path in source_paths] sync_first_sub(source_paths[0], source_paths[1], source_paths[2])Last edited by _Al_; 18th Nov 2021 at 10:28.
Multi-line, heavily stylized subtitles (ASS) possible on Blu-ray?
By Deli295 in forum Authoring (Blu-ray)Replies: 12Last Post: 25th Jan 2021, 15:41 -
Python Batch Creating avs Scripts
By pandachinoman in forum ProgrammingReplies: 5Last Post: 23rd Oct 2020, 09:18 -
Get a list of Youtube video titles from a list of URLs
By abolibibelot in forum Video Streaming DownloadingReplies: 3Last Post: 12th Oct 2020, 04:42 -
Help Needed With Python ffprobe Script
By chris319 in forum ProgrammingReplies: 11Last Post: 28th Jun 2019, 10:15 -
Synchronizing Subtitles - DVD / Bluray x Netflix / Youtube / Similar Sites
By devilcoelhodog in forum SubtitleReplies: 4Last Post: 2nd Feb 2018, 14:48
