When I pause a video with potplayer and the display sleeps while the audio output device is via HDMI or DP, there would be no audio and the video will play frame by frame when the video is resumed after the screen has waked. It only started happening since spring 2020, iirc even before windows 10 2004 update
Things I've tried:
-reset potplayer to default settings
-latest beta
-2019 builds
-2018 builds
-2016 builds
-multiple windows reinstalls
-windows 10
-windows 11
-different hdmi displays
-downgrading nvidia gpu and hdmi audio drivers
-new hdmi tv
My setup has 1 DP->HDMI monitor and 1 HDMI TV connected if this matters, since I've seen one post online that indicate this might be related to multi monitor setups
Most important part is using other players like MPC-HC would have zero issues and would still have audio no matter how long I pause it. I really hope there would be a fix since I don't really like using MPC.
Anyone having similar issues?
What is selected as the Windows 10 output device/playback device for Sound? (Look under Settings->System->Sound or look at Control Panel output device settings for sound.)
PotPlayer/VLC, display multiple cover art images.
By Art Poulos in forum AudioReplies: 1Last Post: 12th May 2020, 18:17 -
PotPlayer - Playing HDR on TV from PC via HDMI
By gropax in forum Software PlayingReplies: 0Last Post: 2nd May 2020, 14:46 -
Audio drops out part with through HDMI capture
By nick1977 in forum Capturing and VCRReplies: 10Last Post: 10th Apr 2020, 08:52 -
potplayer display info text resize
By wtfiwinomgs in forum Software PlayingReplies: 4Last Post: 14th Feb 2020, 23:08 -
HDMI signal will not display
By DillonSUG in forum Newbie / General discussionsReplies: 11Last Post: 21st Nov 2018, 13:02
