This is unedited (except for it being isolated with the use of MKVToolNix) footage. It is a progressive source, no telecine or interlacing.
What is it? I'm not very experienced with video editing, but this is a really distracting effect! I tried applying an effect called DeFlicker but it didn't change anything.
From the description deflickering sounds right.
In this case some temporal denoising using for example:
looks fine to me,... only problem with the denoising is that you know easier spot the video glitches on the forhead,..Code:#DeSpot clip = lostfunc.DeSpot(o=clip) # cropping the video to 1440x1080 clip = core.std.CropRel(clip=clip, left=240, right=240, top=0, bottom=0) # removing grain using MCDegrain clip = mcdegrainsharp.mcdegrainsharp(clip=clip, csharp=0.60))
Frame 68/69/70:
(you need to switch between them to see the problem or watch the video)
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Try this in AviSynth:
There's still a little flicker but it may be slight enough not to bother you. You can further reduce the flicker by raising tr to 3 or more. But as you go higher you will get more of the motion distortions in the forehead (as can be seen in Selur's sample).Code:LWLibavVideoSource("andygriffithtest.mkv") Crop(240,0,-240,-0) SMDegrain (tr=2, thSAD=1000, refinemotion=true, contrasharp=true, PreFilter=4, mode=2, truemotion=true, plane=0, chroma=false) GreyScale()
My christening video is flickering! How to fix that?
By asdigital in forum EditingReplies: 0Last Post: 15th May 2021, 09:03 -
Flickering/bouncing effect while grabbing shakey moments from Video8
By Stanley in forum Capturing and VCRReplies: 13Last Post: 16th Nov 2020, 19:13 -
Low Light Video Noise Fix
By paulmolive in forum RestorationReplies: 38Last Post: 25th Sep 2020, 17:23 -
Flickering light effect on Vegas
By rocco123 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2018, 10:41 -
easy way to fix a low light video recording
By paleskin in forum Newbie / General discussionsReplies: 5Last Post: 20th Mar 2017, 08:13
