Hello,
I have used a Panasonic LS83 for many years now,it was region free hacked a long time ago with a remote hack.Even though the LS86 & LS83 models are not supplied with a remote control and the sensor window on the front is blocked off white all the guts for remote use are in there.By accident I discovered that the remote control for my old LS5 worked with the LS83.
Anyway here's the issue - bought a LS86 model which looked the same as the LS83.Unboxed it tried to play a region 2 dvd - " This disc cannot be played in your region".Same with region 1 and region 4 discs.It would play region free and DVD-R.Couldn't work it out at all then I noticed on the box "REGION 3".
The hack remote I have used for my LS5 & LS83 does not work.I have contacted a few hack sellers on Ebay but they all say they cannot supply a remote hack to go from region 3 to region free.And one said no remote hack would work as the LS86 has no remote sensor - but it does.Only remote hacks I can find for sale are for going from Region 2 to region free.
Anywhere to go to get a custom made hack remote to go from region 3 starting point ?.
found this - https://www.videohelp.com/dvdhacks/panasonic-dvd-ls83/9510
but the link inside that page appears to be dead
Region Hack Panasonic DMP-BDT180
By sound1983 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Sep 2020, 11:55 -
Need region code hack for Panasonic PVD4745S
By cjaiea2 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Aug 2020, 11:07 -
How to make panasonic sc-xh315 region free
By Marcbali in forum DVD & Blu-ray PlayersReplies: 3Last Post: 28th Jun 2018, 21:01 -
region free blu ray player suddenly won't play certain set of disks
By fredgarv in forum DVD & Blu-ray PlayersReplies: 4Last Post: 19th Apr 2018, 21:56 -
How to set the Sylvania SDVD1032 as Region 0 (Region Free)
By jharris1993 in forum User guidesReplies: 0Last Post: 7th May 2017, 21:19
