Results 1 to 25 of 25
  1. very newbie so apologies for what I'm sure is a very simple use case.
    I have a simple MP4 file w/1 AVC video track, 1 audio track eac3, and 2 subtitles. I'm happy with everything in it
    All I want to do is a straight copy of the 4 elements from this MP4 over to another MP4 with a single change to the subtitle 2 track to be flagged as forced ?
    Alternatively I'd like to accomplish the same exact thing, straight across elemental copies no re-encoding anything over to a MKV container (I can change that single flag rather easily in a mkv with tools I'm familiar with)
    Sorry for the simple question, seems everything I try it starts rebuilding all the tracks - I started off as simple as I could make it "ffmpeg -i input.mp4 output.mkv"
    Thanks for any pointers
    Aug 2017
    mkvtoolnix. You're welcome.
  3. It's called a remux or re-multiplex.
  4. Originally Posted by SaurusX View Post
    got that, doesn't help until I can get it put in a mkv unchanged first. Doesn't understand MP4's
  5. Originally Posted by bwbob View Post
    Drag & drop the mp4 into the upper window.
  6. Originally Posted by ProWo View Post
    Thanks ! I found that before and it almost works perfect, it only "sees" and shows the 1 video track and the 1 audio track to select in the lower box, the 2 subtitle tracks text 1 and text 2 don't show up in the selection box. Multiplexing it is almost instant and video and audio copy straight across but in the new mkv both subtitles are missing
  7. Post a mediainfo report (text mode) from your mp4 here
  8. Originally Posted by ProWo View Post
    Thanks - its below. what I'm trying to fix is the 3rd from the bottom field, it's a forced subtitle but not flagged as such.
    Everything else I'm trying to just straight copy across with no changes, it can stay in an MP4 or into a MKV
  9. Try clever Ffmpeg-GUI.
    Load your mp4, click main, click multiplex, set mkv as container, set only one subtitle as forced, click multiplex. Done.
    Should work.
  10. Originally Posted by ProWo View Post
    Should work.
    Worked very well - THANKS !
    Noticed a couple of things, if I left it to multiplex from MP4 still to a MP4 the Codec ID at the top general portion changed from mp42 to isom in the new file and the video was very very slightly altered bit rate and size? Is it unable to be transferred over unaltered? And the forced flag was not set for the 2nd subtitle track even though it was checked (tried it twice) but it does work when converting to MKV.
    When going to MKV the subtitle codec was changed from tx3g to UTF8 which did not occur in the MP4 to MP4? Is that a MKV standard? But the forced flag did get set correctly for the 2nd subtitle !
    Very nice little front end ! Attached mediainfos for each
  11. Originally Posted by bwbob View Post
    Muxing from mp4 to mp4 doesn't alterate the videostream. It is copied as is, the differences in the info are from muxer itself.
    When going to MKV the subtitle codec was changed from tx3g to UTF8 which did not occur in the MP4 to MP4? Is that a MKV standard? But the forced flag did get set correctly for the 2d subtitle
    Ffmpeg is unable to set the forced flag in mp4 container.
  12. thanks for all the help... off to mkv's for me
  13. Note that timed text subs from mp4 files isn't supported by mkvtoolnix. They must first be converted to another sub format like SRT.
  14. Member dashas's Avatar
    Jul 2010
    Yandina Sunshine Coast Qld Australia
    If I can just butt in and ak a Question Please? Does this program Remuxx MKV into AVI or MP4 I have hunted and tried HBrk wont do it, Pargyalem Russhion was Good it gone everything else has gone now Cheers dasas
  15. Originally Posted by dashas View Post
    Yes, if the single streams codecs are compatible with the container, clever Ffmpeg-GUI can mux to 3gp, asf, avi, m2ts, mov, mpg, mp4, mkv, ts, vob, mfx, webm.
  16. Member dashas's Avatar
    Jul 2010
    G/Day ProMo I tred cleverFFmpeg and it was a virus once I loaded it it said I had to download 3 other appps before it would Work? Paryglem (Russian) or somthinng like that was simple to use but it's nolonger around any Ideas I only want to convert MKV to MP4 Thanks ProWo dashas
  17. The virus massage is false alarm.
    The 3 other files to download are the binaries from ffmpeg itself (ffmpeg.exe, ffprobe.exe, ffplay.exe), not included in the download of clever Ffmpeg-GUI.
  18. Member dashas's Avatar
    Jul 2010
    Thank Mate It takes awhile but do eventually catch on? Those other downloads must have been from another program I tried, Not yours Thans again Cobba I wll catch U later dashas
  19. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Quite possibly the subtitles in the mp4 file are "timed text". MKVToolNix doesn't recognise them so they don't appear. Maybe the file is ex Apple? Anyway you need to extract the subs from the mp4 file as srt and then include them with the mp4 you drag into MKVToolNix.
  20. Originally Posted by netmask56 View Post
    The OP gave mediainfo reports in posts 9 and 11. They files are mp4 and the subs are indeed Timed Text. I pointed out in post 14 that Timed Text subs aren't supported by mkvtoolnix so they need to be converted to SRT (or some other supported format). That's what ffmpeg (via ProWo's Clever GUI) is doing for him (without the need to demux the subs).
  21. Banned
    Aug 2020
    Cumi
    Avidemux & Xmedia Recode are more than enough for such tasks.
  22. Originally Posted by Truthler View Post
    Neither avidemux nor xmediarecode can do that.
  23. @ProWo. I'm still working my way through this. Using the latest version of Clever that does a great job of getting the forced subtitle over correctly and flagged.
    Issue I'm having now is the scale of the converted subtitle is too large. Where can I adjust that either before its muxed or after, I'm not seeing a place in MKVtoolnix to change it once done so I'm guessing it needs to be done as part of the MP4 to MKV conversion process.
    Couple of quick screenshots so it makes sense. Thanks for all the help
Name:	Screenshot OrigMP4.jpg
Name:	Screenshot Muxed.jpg
  24. Srt subtitles can not be resized, the player determines the size during playback.
    If you want to resize them, you have to convert srt to ass.
    You can do that with clever ffmpeg-GUI.
    For further adjustments you can edit the ass subtitle in Subtitle edit and then mux it with clever FFmpeg-GUI.
